1986 Corolla SR5 S2k Build.... MIami style
08-26-2010, 06:37 AM
Wassup Folks...
Me and my father in law has beeen working on this project... he bought the car about 6months ago... just shell. From there we slowly got S2k parts... -Motor is a 2006... we knew it was drive by wire > SOoo i thought all that was needed was a TB... NO. NO NO.. LOL We had to change the complete mani + TB, valve cover + cam sensors,04 engine harness+ ecu, crank sensor + crank teeth sensor > we went over all to a 2004 !! -Trans is a > 2005 > Stock clutch for now.. - 2 peice drive shaft - GTS gas tank - wire tuck - Stock S2k ecu 04 -3 inch exhaust + Vibrant tip -JSP engine Mount kit : ) -Radiator got Custom fitted + water necks turned by CAKES FAB !! We are also running a S2k cluster.. + s2k dash harness........ : ) wiring has been a mish but almost done... Car starts now .... just have 3 bugs to get rid of.... I got alot of pics to come........... START UP VID !! > http://www.youtube.com/watch?v=3wYGEx8rS_A When we got her !! Motor... Trans..... Steering spline "extended" OIL pan ... cut n welded cause it was touching > Subframe !! Subfram... cut and welded !! Test fit..... did this like 6 times !! .. just to make sure we had enough clearance in the tunnel of the tranny... Strip down and cover a few holes... then PAINT !!! 3 Inch FTW... Griffin Rad... With Custom work done to it by CAKES FAB !! !! DOG POWER !! |
08-26-2010, 07:56 AM
is that a std. rear axle? you might want to change that for something stronger
08-26-2010, 05:54 PM
Probably need celica/supra rear.
08-28-2010, 01:33 PM
meh, the t series??? can last well if looked after. and lsd choice is important. josh young ran a tseries behind his turbo 4age for i think 3 drift seasons and it never broke.
but driving style has a lot to do with longevity looks great man, how much did you have to space the crossmember down to fit it all in? clutch kick, switch, tree .... oowwww |
09-23-2010, 07:18 PM
09-27-2010, 09:50 AM
I like your style! ;-)
09-27-2010, 05:43 PM
love that conversion
10-21-2010, 05:48 PM
thanks......^^
10-21-2010, 09:41 PM
any pics of how the oilpan clears the subframe and the gearbox clears the tunnel tunnel now?
http://monkeymagic86.wordpress.com |
10-22-2010, 04:33 PM
s2k + ae is ideal combo, sadly i can't ftw..
so fucking expensive engine here ( congrats owau no ka "I" |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,037 |
OST-050 - a VERY special build | oldeskewltoy | 49 | 36,175 |
01-05-2019 07:03 PM Last Post: oldeskewltoy |
d3nso's little AE86 N2 build | d3nso | 27 | 34,825 |
11-13-2017 11:42 AM Last Post: mad.matt |
Beams Levin build | mannix20vt | 5 | 9,302 |
Drift missile build [FIN] | TuGeTu | 7 | 20,806 |
11-09-2015 06:13 PM Last Post: mad.matt |
