20V Blacktop ConRods
11-06-2011, 09:17 PM
So the 20V BT original conrods seem extremely flimsy and weak.
![]() I guess they will do ok on a stock engine but because I'm in the process of assembling mine from scratch, it seems a good idea to make sure that I have a solid connection between crank and piston. What conrods have you guys been using in your blacktops? I'm considering the Brian Crower ones (42mm and 20mm pins) Center to Center Length -- 4.803" Big End Bore -- 1.772" Big End Width -- 0.859" Pin Bore -- 0.787" Pin Width -- 0.859" Weight -- 415 Grams ![]() http://www.ebay.co.uk/itm/Brian-Crower-S...1919wt_822 As for the pistons, I guess the OEM ones will have do. And I can only find TODA pistons for the BT (apparently different form the Silvertop) which are extremely expensive. The idea is a bit more compression as I will have to skim the head and maybe later go for more lift and a bit more duration on the cams. 86'LEVIN Track Project |
11-06-2011, 11:51 PM
BC work with CP piston and JE, they can make pistons with your own specs
![]() http://www.briancrower.com/makes/toyota/...tons.shtml Arias also make pistons for blackop. |
11-07-2011, 12:21 AM
Good one on the Arias. :wink:
Kept looking for Wiseco and completely forgot about Arias. Thanks! About the BC conrods, did anyone tried them? 86'LEVIN Track Project |
11-07-2011, 12:49 AM
BC make good product so I believe you can buy them with confidence
BTW blacktop conrods aren't weak at all, most guys use them 'cause they are very light and can support 190hp+ :wink: |
11-07-2011, 01:19 AM
Wossner ?
11-07-2011, 01:53 AM
Ops, forgot about 20V part.
Wossner makes only 16V. Sry |
11-07-2011, 07:57 AM
I went with Tomei rods. But why do you need uprated ones? Boosted application?
11-07-2011, 11:33 AM
I can't believe Toyota did not do their homework on the 20v rods.
Is the material spec. on the blacktop rods different to the others ? Any evidence of blacktop rods breaking on a n/a engine other than the bearings letting go ? An analogue brain in a digital World |
11-07-2011, 12:11 PM
totta Crolla Wrote:I can't believe Toyota did not do their homework on the 20v rods.In 10 years, knowledges on material (alloy / process) have significantly evolved. Maybe the material is the same (far as I know, no one have ever analyse them) but by changing only few things on the process it can change radically the stiffness. totta Crolla Wrote:Any evidence of blacktop rods breaking on a n/a engine other than the bearings letting go ?Personally I never heard about blacktop rods breaking for no reason. |
11-07-2011, 12:25 PM
Most of the rebuilds I've seen over the years do contemplate a conrod upgrade, usually to silvertop rods.
As I said above, I guess the OEM ones will do just fine for a stock engine. As I don't want to reopen the bottom end any time soon, I want some peace of mind when it comes to con rods, not just due to compression but primary due to piston speed. I guess the more likely scenario for a connection rod failure in a NA setup would be a traction load and not compression. I'm not yet sure where future head modifications will take this engine to, but if the case presents where I need more rpm (or more compression) to make a setup perform correctly, I don't want to be worrying about rods. So that is the main reason why I think it is a wise decision to invest in stiffer (and lighter actually!) connection rods. 86'LEVIN Track Project |
Refreshed 20v blacktop first start.. | Mylesmck | 6 | 932 |
20v Blacktop conversion.... | Mylesmck | 0 | 551 |
Improve 20V Blacktop cooling | pack | 0 | 1,059 |
06-07-2023 01:18 PM Last Post: pack |
Shims 20V Blacktop | CHOPKIN2 | 3 | 4,865 |
12-23-2017 11:07 PM Last Post: oldeskewltoy |
stock injector deadtime for 4age 20v silvertop/blacktop injector | ditn | 1 | 5,981 |
