20V Blacktop ConRods
11-07-2011, 01:47 PM
Have you seen a BT rod break in the middle? I haven't and that's where it's the thinnest. They usually crack near the crown / bolts. I'd upgrade them with ARP if you aren't planning revving it over 8500
[Image: AEU86 AE86 - 20V Blacktop ConRods]
11-07-2011, 01:50 PM
More compression will not necessitate different rods. Only high rpm and 1bar+ boost will. I'd suggest you save yourself the rod+piston money and invest that into good porting work + cam matching.
Take a look at the Touge 200 series on youtube or DVD. One of the episodes has an AE86 fielded by the owner of the shop that prepares Tsuchia san's hachi. Stock rev limit/exhaust/header. 180hp
11-07-2011, 03:09 PM
NoHachi, I believe the chance of failure with mild tuning is very small, but I can't help to think that not improving the rods when I got a chance might kick me in the ass later on.
So the idea was rods only, keeping the stock pistons.
I have to think about it as initially I wasn't considering altering the bottom end.
I might just say "what the hell" and use the investment help cover a set of high lift cams. Tongue
86'LEVIN Track Project
11-07-2011, 04:30 PM
The cams won't do much without the head work. You need a place that does one stop shopping headwork+matched cams. You can find them still, mostly doing rally engines. Better investment then high rpm/big cam/stock head.
11-07-2011, 04:38 PM
Some of the head work is being done now. 3 angle valve job and getting rid of cast defects.
I'll probably start with oem cams and see how it does and drives.
Maybe then I'll think about further head work, cams and compression.
11-07-2011, 04:41 PM
Headwork + cams + stand alone management -> this is the real deal ! Cool
01-12-2012, 07:51 PM
I was reving the day light out of my AE111.
The rods never let go.
02-21-2012, 07:40 PM
I have seen a big hole in front and in the back of a Blacktop engine block. The engine was revving at 1500rpm and it had no noises or other, just before it broke. It just broke. Confused
If I build me a new engine, I will not use theese con rods. But that just my opinion.
Project AE86 now begun.
Cars I have owned:
Toyota Starlet EP91 1,3 16v Turbo, 200hp
Toyota Starlet EP71 1,3 12v Sport
Mercedes 207D camper, 1977.
Toyota Starlet EP70 with a 174hp Silvertop 20v See video here:
http://videos.streetfire.net/search/Star...079edc.htm
Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint).
Volvo 240 2,1 (The only car I have maked money on).
Toyota Corolla EE90 (my first car)
  Refreshed 20v blacktop first start.. Mylesmck 6 932 10-07-2024 07:55 AM
  20v Blacktop conversion.... Mylesmck 0 551 04-29-2024 05:48 PM
Last Post: Mylesmck
  Improve 20V Blacktop cooling pack 0 1,059 06-07-2023 01:18 PM
Last Post: pack
  Shims 20V Blacktop CHOPKIN2 3 4,865 12-23-2017 11:07 PM
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 5,981 02-20-2016 11:48 AM
