20V VVT on standalone ECU
08-07-2013, 04:25 AM
Hi,
anyone done it before? There is very litte or no infomation avaliable. If anyone got any, please share expirience and informationSmile
I´ve had a blacktop running on a OMEX 600 before which could only act as a on-off switch related to rpm (like Honda VTEC), done 2 dyno runs and ended up disableing it, since it caused big torqueloss for the sake of 3hp.
Defiantly not worth it...
Now on a different car Emerald K3 is supposed to be able to control VVT, BUT I´ve got no idea how the 20V solenoid need to be triggered and the emerald manual doesnt cover it.
Sad
Any ideas?
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
08-07-2013, 09:52 AM
put back on the OMEX600 and I can show you how it is done
it is very simpel :-)
08-07-2013, 07:57 PM
Rene is right. Omex600 can do it. I have been in one that was a ST with a omex 600 and it was quicker then a standard BT with standard ECU.
I don't know (could be Rene) but there is a company in Holland that tunes 20V with Omex 600 for kitcars.
08-08-2013, 10:51 AM
See if you can find these under the "Additional Maps" tab in the Emerald
software. If you have the tables, you should be able to implement VVT
control of some kind.
[Image: AEU86 AE86 - 20V VVT on standalone ECU]
Cam on/ off switching control. Switch according to rpm and load.
Any spare output can be assigned to this function.
Rover VVC control.
Continuously variable cam duration.
Control target duration according to load and speed table.
Oil temperature correction to control algorithm.
The VVT switch is a simple rpm/load on/off setup controlled by the ECU.
The VVT control is a more sophisticated system, modulating the VVT
solenoid according to rpm/load, and requires both crank and cam sensors
to allow the ECU to monitor the degrees of cam advance or retard. I did
not find any reference to this in the documentation, so I don't know if this
runs in closed or open loop... open loop I would guess.
Cheers... jondee86
PS: With Toyota 20V engines, I believe that (@ WOT) there is an optimum
lower rpm for turning the VVT on, and above a certain higher rpm it
should be turned off, for best performance. Maybe that's all you need, and
you could possibly use the A/C enable output ?? Talk to Emerald Smile
08-09-2013, 09:27 AM
hi
the 20 V engine is a simpel on/off valve so use the PWM table if there not are a output you can controll with rpm
0% to where you to set it off and 100% to put it on
and off at low rpm on where you want torque and off at high rpm to get the last hk
I don't think you get the VVT function to work because you don't have a feed back from the cam, but you can try
but email me if you have quastions
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 2,266 05-26-2024 07:40 PM
Last Post: totta Crolla
  20v BT conversion ECU izanagi 5 6,827 06-14-2016 02:39 PM
Last Post: izanagi
  ITB convert need standalone ECU izanagi 2 6,640 04-07-2016 11:24 PM
Last Post: izanagi
  20V blacktop. what kind off ecu??? slowboy2 11 13,750 07-17-2015 07:01 PM
Last Post: jdm86gtz
  16V ECU pinout on 20v swap pack 2 5,454 06-12-2015 01:22 AM
Last Post: pack
