20v BT Head
02-24-2025, 05:55 PM
20v BT Head
hi all,
I'm searching a hard to find value :
Engine 4age 20v Blacktop: what is the head cylinder volume( for 1 cylinder)????
Impossible to get an answer ....
mine is 29cc , but I suppose it has been milled ?
I'm rebuilding the engine and got Toda forged pistons .
Trying to find the correct head gasket thickness, as the Toda pistons will increase the
CR.
Toda says I can use a 0.8mm thickness , but with a stock head cylinder...
Hard to find a reliable answer .
Thanks for helping
Phil
Filh
Save the RWD cars
02-24-2025, 10:55 PM
20v BT Head
According to SQ Engineering, they measured it to be 37.8cc:
https://www.sq-engineering.com/tech-arti...1ed7090bfa
[Image: AEU86 AE86 - 20v BT Head]
02-25-2025, 03:09 PM
20v BT Head
Thanks Banpei.
I read the article , but didn't notice the Blacktop CH .
Saw it now .Pffff Beeing old is awfulDodgy
Thanks again
Filh
Save the RWD cars
02-25-2025, 11:16 PM
20v BT Head
No worries, I'm already at the age where I can't do without reading glasses... Big Grin
03-11-2025, 09:51 PM (This post was last modified: 03-11-2025 09:58 PM by oldeskewltoy.)
20v BT Head
I've actually measured.... 38cc
A LOT of inaccurate info in that article.
1) Silvertop chamber = 36cc
2) headgasket thickness = 1.25mm
3) Blacktop head = 38cc
Oh... uncut blacktop head = 124.50mm
Dan -
  How to install 20V ITB on 16V head Mr.komp 7 12,156 12-28-2015 05:35 PM
Last Post: pack
  20v block with 16v head and internals possible? ditn 3 7,232 08-12-2014 09:19 PM
Last Post: ditn
  Machining Pistons to run 20v head... And FCR's on a 20v? PazzaAE86 2 5,243 09-15-2013 01:08 AM
Last Post: jondee86
  20V Head and Crankbolt Removal. unahanaretsu 8 8,686 09-23-2010 11:45 PM
Last Post: jondee86
  20v bt swap to ae86 (20v or 16v flywheel????) kid 11 15,321 12-08-2007 04:09 PM
Last Post: Jan Pedersen
