20v BT - which oil pump?
05-09-2022, 04:30 PM
Hi folks!
I'm rebuilding a 20v blacktop for my AE86. Was wondering what is involved in changing to the silvertop timing belt/tensioner, as I understand it is less problematic than the hydraulic tensioner of the BT. Also, the timing belt is about half the price of the blacktop. I have two oil pumps; the original BT pump (engine spun a bearing so it would be no harm to discard that), and a 16v type - which looks very clean & may not have seen much abuse. I also have a new genuine pump gear set. Is there anything I need to be aware of when doing this? Also, the previous tensioner was welded/brazed onto the dowel on the pump ![]() |
05-12-2022, 03:43 PM
the dowel is important for the tensioner....
If you really want to run a silvertop type pump , I'd recommend you just buy a new Aisin OPT-036. I would recommend a few drops of assembly lube inside it before assembly. Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-29-2022, 02:34 PM
(05-09-2022 04:30 PM)Mylesmck Wrote: Hi folks! i recommend to see this video: https://www.youtube.com/watch?v=HwCchrZI...ng4answers http://www.ae86rd.com |
06-03-2022, 12:49 PM
Yeah thanks Chacaman, I've seen that video. Unfortunately it doesn't mention the tensioner and I've already got a later gearset to install into the pump housing
Sent from my ANE-LX1 using Tapatalk |
06-21-2022, 04:51 PM
Pick up the OEM part number for BT and search the AISIN pumps (OEM supplier) half the price
Fuel pump issue | DJexor | 11 | 6,804 |
fuel line hose from the pump | Wikizz | 4 | 6,761 |
Rim width. Which is best.... | Dino86 | 5 | 7,495 |
which connector is this | ditn | 7 | 8,609 |
07-27-2015 11:24 AM Last Post: pack |
Haslbeck front spoiler, which foglights? | wouter86 | 2 | 5,591 |
02-15-2015 11:14 AM Last Post: ditn |
