20v BT - which oil pump?
05-09-2022, 04:30 PM
Hi folks!
I'm rebuilding a 20v blacktop for my AE86. Was wondering what is involved in changing to the silvertop timing belt/tensioner, as I understand it is less problematic than the hydraulic tensioner of the BT. Also, the timing belt is about half the price of the blacktop. I have two oil pumps; the original BT pump (engine spun a bearing so it would be no harm to discard that), and a 16v type - which looks very clean & may not have seen much abuse. I also have a new genuine pump gear set.
Is there anything I need to be aware of when doing this? Also, the previous tensioner was welded/brazed onto the dowel on the pump Huh but I've since ground that off and the dowel came off with it!
05-12-2022, 03:43 PM
the dowel is important for the tensioner....
If you really want to run a silvertop type pump , I'd recommend you just buy a new Aisin OPT-036. I would recommend a few drops of assembly lube inside it before assembly.
Dan -
05-29-2022, 02:34 PM
(05-09-2022 04:30 PM)Mylesmck Wrote:  Hi folks!
i recommend to see this video: https://www.youtube.com/watch?v=HwCchrZI...ng4answers
http://www.ae86rd.com
06-03-2022, 12:49 PM
Yeah thanks Chacaman, I've seen that video. Unfortunately it doesn't mention the tensioner and I've already got a later gearset to install into the pump housing
Sent from my ANE-LX1 using Tapatalk
06-21-2022, 04:51 PM
Pick up the OEM part number for BT and search the AISIN pumps (OEM supplier) half the price
  Fuel pump issue DJexor 11 5,742 04-29-2022 05:45 AM
  fuel line hose from the pump Wikizz 4 6,248 10-16-2017 07:11 PM
Last Post: jdm86gtz
  Rim width. Which is best.... Dino86 5 6,995 01-07-2017 03:09 PM
Last Post: Dino86
  which connector is this ditn 7 8,020 07-27-2015 11:24 AM
Last Post: pack
  Haslbeck front spoiler, which foglights? wouter86 2 5,225 02-15-2015 11:14 AM
Last Post: ditn
