20v Silvertop - New Haltech ECU & Couple of questions
05-26-2024, 07:40 PM
(04-22-2024 08:51 AM)Ivan141 Wrote:  If you want an interesting read, have a look at this:
https://grassrootsmotorsports.com/forum/...59/page31/
Common MAP sensor solutions for ITB's are flawed at best (if you're not using some sort of plenum). But alpha-N is arguably not better.
This guy claims to have solved the issue by running one map sensor per runner and passing the lowest reading to the ECU.
Quite a simple solution from an electronical standpoint, but a very pricy one if you look at the prices of MAP sensors.
I built my own analogue of this using more affordable but equally capable MAP sensors but I still need to finish a workable prototype
since the cheaper sensors need a 3D-printed 'manifold' as they do not have their own hose barbs.
I agree about Alpha-n not being better, in this it might be easier.
Do you know what the Toyota ecu strategy is?
  Windscreen stoopid(?) questions.... Mylesmck 7 1,545 04-30-2024 09:46 PM
Last Post: Mylesmck
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 14,120 07-18-2019 03:52 PM
  Brake Bias Questions mad.matt 10 11,931 01-03-2019 04:54 AM
  20v silvertop idle issue AlexFourTwenty 3 5,397 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
  wider rear axle,track width,suspension questions ditn 6 9,272 10-18-2016 11:50 AM
Last Post: fantapants
