20v distributor
01-20-2008, 08:48 PM
20v distributor
When running a 20v engine ("modified" bulkhead) with a standard distributor is there enough room to remove the cap and change the rotor arm ?
01-20-2008, 09:38 PM
20v distributor
That would depend on how "modified" the bulkhead is Wink But I don't think there will be enough room.
[Image: AEU86 AE86 - 20v distributor]
01-21-2008, 01:42 PM
20v distributor
Jan Pedersen Wrote:That would depend on how "modified" the bulkhead is Wink But I don't think there will be enough room.
mmm.. I've seen rotor arms break on a rally car before, a two minute fix normally.
Taking the engine out on a rally, might be a problem Smile
  16v distributor hole plug harkes 8 9,446 10-12-2016 11:13 AM
Last Post: harkes
  Changing distributor when carb 4age izanagi 14 15,281 07-04-2016 03:27 PM
Last Post: Uzelac
  Machining Pistons to run 20v head... And FCR's on a 20v? PazzaAE86 2 5,090 09-15-2013 01:08 AM
Last Post: jondee86
  Distributor position and cranking pack 13 19,187 07-01-2013 11:08 PM
Last Post: pack
  weak spark. new distributor? please help. stasis_dc5 3 7,123 04-11-2011 12:35 AM
Last Post: fax0815
