20v into 85
08-06-2006, 11:12 AM
20v into 85
hi there. I have used search but didnt find the answer.
I have an 85 and next week im planing to get 20v silvertop for it, the problem is i dont want to bash my firewall to use original dizzy. i plan to control my eng with LINK ecu, so i can use aftermarket cam shafts. And that gives me abbility tu use coil packs instead of dizzy. But the question is what should replace the dizzi with? Do i use the 4a-gze crank angle sensor, If so what do i do to make it fit? 4a-ge dizzy and 4a-gze crank angle sensor seems to have different pulleys. Or can i pick up the signal from the dizzy's base, without the dizzy cap? |
08-06-2006, 11:44 AM
20v into 85
just make a hole in the fire wall,simpel way to make the 20valve thing happen
sr86 completed!!........漂うことのマスター!!!! |
08-06-2006, 12:12 PM
20v into 85
thanks but i've said that im not goin to make a hole in my firewall.
If i do that then i'll get all sorts of certification problems. |
08-06-2006, 04:55 PM
20v into 85
I think yous should be able to remove most of the pointy bits of the dizzy poking into the firewall..Just remove cap and apply hacksaw to the rest, making sure to keep the Hall pickup bit intact.
08-06-2006, 07:13 PM
20v into 85
u could use a number of coil setups with megasquirt u can use dtock dizzy as a crank angle sendor like this http://forums.club4ag.com/topic.asp?TOPIC_ID=132260
thats what im doin u can use gze coils or mazga coil/ignitor or u can use a edis or any workable ignition setup with the megasquirt im using a megasquirt 1version 3 "life begins at 8000rpms" - Going Racing |
08-06-2006, 07:48 PM
20v into 85
I have just put in a blacktop in my AE86, and i have just removed the rotor and cap, then there is no problem, with that.
This is not the hardest part to make room for, that is the water, that is comming out the back!!, this is sticking a fair bit longer out. /Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
09-15-2006, 12:31 AM
20v into 85
Get on to Rawengineering.co.uk they put the 20v into kit cars and have done a few twinners as well they wer very helpful to me & stageoneimports do a very neet but expencive coolant rerouting pipes
09-15-2006, 10:03 AM
20v into 85
Phatbob on http://www.driftworks.co.uk does a VEMS distributerless engine management system which uses a crank angle sensor & coilpacks for STGĀ£500 750yoyo
Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 8,366 |
12-19-2021 11:58 PM Last Post: gh0st |
Machining Pistons to run 20v head... And FCR's on a 20v? | PazzaAE86 | 2 | 5,158 |
09-15-2013 01:08 AM Last Post: jondee86 |
AE92 brake booster and master cylinder into AE86 | bel_air | 8 | 12,486 |
08-02-2012 10:51 AM Last Post: bel_air |
bluetop 4age cams into 4agze ? | Okami | 9 | 12,595 |
04-08-2012 07:51 PM Last Post: corolla4agze |
Longer 5th gear into T50 | stratosTRD | 3 | 4,864 |
06-16-2011 08:36 PM Last Post: stratosTRD |
