20v silvertop change
06-11-2008, 02:32 PM
I currently have a 4AGE 16v running ITB's, it died last weekend so I am going to change for a silvertop. I not worried about wiring as I run a stand alone ECU so should be pretty straight forward.
Is there anything I need to know before I start regarding , clutch, flywheel etc.
Where do you get parts for the silvertop, cam belt, oil filter etc are these the same as the 16 valve.
PS: I will be selling a complete set of ITB's on T3 maifold, just taken off a perfectly running car, anyone interested pm me, I will be putting a post in the buy/sell section soon.
Ivan
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
06-11-2008, 03:17 PM
silvertop items are available trough the toyota dealer. Also you can get them trough ebay.
How did you arrange spark ? As this is on a diffrent location on a silvertop. Also the waterlines are diffrent. You will need to adjust the way the waterlines run.
06-11-2008, 05:01 PM
I will just be using the same method as on the 16 valve, I have a trigger wheel and CPS for my ECU.
Ivan
06-12-2008, 09:23 AM
Why a sivertop engine? Wny not a blacktop engine?
There is only one true Nismo at AEU86
06-12-2008, 11:36 AM
The blacktop is a few hundred quid more expensive and has only a few more hp, also the hp is moved further up the rev range. It will be installed in a 700kg MG midget so the silvertop should be enough.
Ivan
06-12-2008, 12:17 PM
besides dump is some diffrent cams and you will surpass the blacktop with ease. And the invesment will come to the same price as a blacktop engine.
06-13-2008, 08:09 PM
Make sure you get the pilot bearing for the crankshaft as well.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 2,027 05-26-2024 07:40 PM
Last Post: totta Crolla
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,321 07-18-2019 03:52 PM
  20v silvertop idle issue AlexFourTwenty 3 5,118 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 5,817 02-20-2016 11:48 AM
  trans oil, lsd oil change Apolan 9 16,938 10-01-2014 03:57 PM
