20v silvertop idle issue
12-22-2017, 04:19 AM
Hello guys. It’s a silvertop 20v stock ecu just has throttle opener and metal vacuum lines under itbs removed no canister no egr. No pwrsyering no a/c. Starts up then dies a second later. I can however keep it running if I keep accelerated depressed a bit. If I disconnect the afm it runs and idles just kinda rich. It’s not the afm because I replaced it with a known good one and it’s not the iscv I took it off inspected cleaned and put back. Is there some sort of throttle adjustment on silvertop 20v ?
12-23-2017, 11:30 PM
(12-22-2017 04:19 AM)AlexFourTwenty Wrote:  Hello guys. It’s a silvertop 20v stock ecu just has throttle opener and metal vacuum lines under itbs removed no canister no egr. No pwrsyering no a/c. Starts up then dies a second later. I can however keep it running if I keep accelerated depressed a bit. If I disconnect the afm it runs and idles just kinda rich. It’s not the afm because I replaced it with a known good one and it’s not the iscv I took it off inspected cleaned and put back. Is there some sort of throttle adjustment on silvertop 20v ?
Problem solved..
12-24-2017, 01:17 AM
If you got some spare time let us know how you fixed it, as it might help others in the future Wink
12-24-2017, 03:27 AM (This post was last modified: 12-24-2017 03:29 AM by AlexFourTwenty.)
(12-24-2017 01:17 AM)Bean Wrote:  If you got some spare time let us know how you fixed it, as it might help others in the future Wink
Well I just had to block the iscv and reinstall the throttle stop to set the throttle position. I’m guessing previous owner messed with itb tuning not sure. Rather just live with it.
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 3,063 05-26-2024 07:40 PM
Last Post: totta Crolla
  PWR light issue and no brake fluid after winter storage magpie 10 3,217 05-25-2023 08:09 AM
  No idle below 2000 rpm rich running Steller Engineering 3 1,726 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Fuel pump issue DJexor 11 5,851 04-29-2022 05:45 AM
  Engine starts/revs but no idle GenkiMotors 17 8,184 11-20-2021 04:12 AM
Last Post: GenkiMotors
User(s) browsing this thread:
