20v swap questions
07-29-2007, 04:38 PM
20v swap questions
if i am running the stock Blacktop with Stock ECU.. do i need a airflowmeter?
what othe problems am i running into exept the waterline and distribitor problem? |
07-29-2007, 05:23 PM
20v swap questions
Blacktop runs a map sensor, silvertops run airflow meter.
Here is a little light reading to get you started. http://www.drivingclub.com.au/forums/ind...topic=2457 http://www.drivingclub.com.au/forums/ind...wtopic=557 |
20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 2,004 |
Windscreen stoopid(?) questions.... | Mylesmck | 7 | 914 |
Brake Bias Questions | mad.matt | 10 | 11,047 |
20v swap bell housing | izanagi | 2 | 4,125 |
12-15-2016 01:12 PM Last Post: pack |
20v swap alternator | izanagi | 3 | 4,934 |
12-15-2016 01:11 PM Last Post: pack |
