20v water galleries
01-11-2008, 04:27 PM
20v water galleries
Help needed please, i am currently in the middle of fitting a black top 20v into my ae86 and need some info on the water galleries on the back of the head,not wanting to cut the bulkhead have checked out the chita type kit what i need to know is there are two waterways does the waterway on the inlet side on the back of the head get blanked off as the pictures of the chita conversion back plate seems to show or is there or has the back of this plate been machined in some way to allow the water to travel between the two galleries, any photos or info would be most welcome
01-11-2008, 05:37 PM
20v water galleries
http://koti.phnet.fi/vanaja/ and link "kuvat 1"
01-11-2008, 07:04 PM
20v water galleries
I believe they drill the separating wall between the two chambers in the head so water can flow freely, then blank off the hole.
01-12-2008, 12:18 PM
20v water galleries
Thanks for the quick response,cheers Hopi for the photos i think this is the best option rather than drilling the head as thats a one way street .
Could anyone enlighten me as to what throttle cable to use preferably a toyota item the car is rhd i did read somewhere that a supra cable will fit the pedal and linkage and is long enough but i connot remember which model supra its from or a part number would be great. |
Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 7,399 |
20v conversion water relocation | izanagi | 1 | 5,322 |
06-15-2016 09:45 AM Last Post: banpei |
20v with 16v Water Relocation Kit | D.O | 9 | 15,619 |
06-12-2014 02:48 AM Last Post: jondee86 |
Machining Pistons to run 20v head... And FCR's on a 20v? | PazzaAE86 | 2 | 4,998 |
water pump issues | Alex170984 | 24 | 22,922 |
08-27-2013 02:40 PM Last Post: Alex170984 |
