20v with 16v Water Relocation Kit
06-06-2014, 09:09 AM
GD mates! did not find the convincing answer about 16v waterlink setup on 20v BT, (without drilling the hole in had) just used unite backplate
does the 20v on this setup goes wrong?: 1.what with 4th cilinder does it overheat? 2. less power or bad responsive? Thanks in advance! Rising Sun T |
06-06-2014, 09:50 AM
read here http://s-86.com/technical_articles.php especially the cooling guide.
AE86 ex-daily |
06-06-2014, 01:16 PM
Nice one Bean!
06-07-2014, 10:29 PM
didn't find the answer who use this setup
Rising Sun T |
06-07-2014, 10:46 PM
I'm going to user the RWD water system of the 16v
06-10-2014, 01:07 PM
16V Watersetup on 20V works well, done it on 2 AE86´s.
06-11-2014, 04:42 PM
(This post was last modified: 06-11-2014 04:43 PM by D.O.)
thanx to all! i'm also use this setup, but why many Japan cars use (like t3) kit,
and many people talk that with 16 watersetup engine not run on full potential ?? Rising Sun T |
06-11-2014, 11:51 PM
According to the description provided by SQ Engineering on this
page http://s-86.com/s-newcoolingguide.html the real difference is the temperature of the water passing inside the head on the inlet side. 16V system has the cool water from the radiator entering the block via the pump and exiting the head at the front. 20V (OEM) system has the cool water from the radiator entering the rear of the head, passing along the inlet side, then via the pump into the block and out to the radiator from the rear of the head. If you are running a simple in-line thermostat layout, the volume of water circulating should be sufficient to maintain a low temperature gradient across the engine (inlet to outlet). Therefore, I would not expect to see any significant difference in performance between the OEM system and the 16V RWD conversion. I do have some reservations about the wisdom of running an in-line thermostat without any provision for water by-pass during warmup. The simple in-line thermostat relies on a single 3mm hole to maintain circulation until the thermostst opens. The factory system uses a bypass arrangement to maintain flow through the engine during warmup. This will be more effective in preventing hot spots, and promoting even temperature rise through the head and block. I have not seen anything to suggest that the lack of a factory style bypass is a problem, that's just my personal preference Cheers... jondee86 |
06-12-2014, 12:25 AM
Im adapting the bypass on my 16V water route system... pretty easy actually...
06-12-2014, 02:48 AM
Ideally, a modern dual action type thermostat gives the best temperature
regulation, as the bypass © is actually closed off once the coolant reaches a certain temperature. Thus there is no "short circuiting" of hot coolant when full radiator cooling flow is required. Probably not worth trying to implement such a system on an old engine, but easy enough I would say if you were to use a remote thermostat housing. Cheers... jondee86 |
Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 7,490 |
12-06-2017 06:48 PM Last Post: Bean |
20v conversion water relocation | izanagi | 1 | 5,366 |
06-15-2016 09:45 AM Last Post: banpei |
How to install 20V ITB on 16V head | Mr.komp | 7 | 11,601 |
12-28-2015 05:35 PM Last Post: pack |
16V ECU pinout on 20v swap | pack | 2 | 5,396 |
06-12-2015 01:22 AM Last Post: pack |
20v block with 16v head and internals possible? | ditn | 3 | 6,914 |
08-12-2014 09:19 PM Last Post: ditn |
