3000 v8
10-28-2009, 02:09 PM
3000 v8
did anyone try to install a bmw 3000 v8 in a hachi?
10-28-2009, 02:17 PM
3000 v8
YOU ARE VERY SICK MAN !!!!!!!!!!!!!!!!!!!
10-28-2009, 02:22 PM
3000 v8
why?
10-28-2009, 02:25 PM
3000 v8
i have a 530 v8 bmw back home and i don't know what to do with it ... so i was thinking to ask , i it is possible
10-28-2009, 06:39 PM
3000 v8
BEST MOTOR 4 A G E 16V....THAT'S IT ,NOTHING ELSE.
4AGE 16V-BLUE TOP-CELICA GT
お持ちでない方は上のバナjap spec!
10-28-2009, 07:42 PM
3000 v8
sr20det,MUTCH better Smile
drift ae86:308bhp/435nmEDIT:384pk/498nm!!!!>now DEATH)))
10-28-2009, 08:58 PM
3000 v8
......i don't think soo.... Big Grin Tongue
10-28-2009, 09:08 PM
3000 v8
In terms of engine design I doubt a 16V 4AGE would even stand a chance against a SR18DE. Wink
And looking at the specs of an M60B30 I think the same applies to that engine as well, so I'd say why don't you try it! Tongue
Besides all that IMO a "free" engine is always better than one you have to pay for. Tongue
[Image: AEU86 AE86 - 3000 v8]
10-29-2009, 01:39 AM
3000 v8
sounds sweeeeeeet...
recommend you do a bit of research 1st. Calculate mass differences so you can try to compensate with stiffer front suspension.
Btw... BEST(imho) V8 swap into an AE86.....
It is known as a Hartley V8
Hartley specs page Wrote:SPECIFICATIONS H1V8:
75° odd fire V8
2.8 LITER, 170 cu. in. displacement (3.0 liter optional)
84mm Bore X 63mm Stroke (67 stroke optional)
4 cams, 32 valves via internal silent chain
530mm wide x 485mm long x 530mm high
400HP @ 10,000 rpm with stock street cams (higher spec. is available)
245 ft-lbs torque @ 7500 rpm
200 lbs engine weight
Billet nitrided steel 180° crank
4340 H-beam con-rods with ARP bolts
Billet 6061-T6 aluminum crankcase
Dry sump 0il system with 4 stage pump
7.25" or 5.5" Twin disc clutch
DTA S80 full sequential ECU
The highlighted part is important for ANY engine in an AE86(or xE7x as well)
Dan -
10-29-2009, 11:31 AM
3000 v8
Dry weight:
4A-GE = 120kg / M60 = 203kg
T50 = 27kg / Getrag = 35 - 40kg
Total difference around 100-110kg, once you include bigger exhaust, fuelpump, etc.
HP...jump from 120 to approx 200 or 8.3kg/hp to 5.5kg/hp
Balance jumps from 51F/49R to 55F/45R
Basically you create your own version of the E30
