4 age camshaft
07-13-2006, 12:39 PM
4 age camshaft
Dear all,
I was wondering how to improve performance of my 4 age small port. Start with lower end or do you recommend cams. Was thinking about 256 or 264 cams. The car is for road use and initial track day use. Best regards Jos |
07-13-2006, 01:10 PM
4 age camshaft
Try this first:
http://www.club4ag.com/faq%20and%20tech_..._story.htm |
07-15-2006, 08:39 AM
4 age camshaft
Thanks for the tip !
07-17-2006, 06:01 PM
4 age camshaft
since I am driving a small port I was thinking to use the big ports
cams/ they have a bit more duration and lift . is it wise ? |
07-17-2006, 06:28 PM
4 age camshaft
Lots of work, for very little improvement. I'll bet that you wouldn't notice the power increase if you didn't know they had been changed.\
Its worth doing if you have the head open anyway, but I wouldn't tear apart the head just for this swap. A wheel to steer the front of the car A pedal to steer the rear |
07-18-2006, 07:54 AM
4 age camshaft
for 256 & 264 cams you'll feel really little improvement, you dont even need adj cam gear to tune 256 and 264, i'll say go with 264/272, max your Stock ECU can handle with a little rough idle, but you'll squeeze more fun out of that with the same amount of $$$
P.A.S.S Racing 148 S.8th Ave, Unit-F (626)961-6284 City of Industry [email protected] http://www.passracing.com |
07-18-2006, 08:52 AM
4 age camshaft
thanks!
I was thinking about 256 cams instead of the original 232 in my small port. but will do so after the summer season lets say oktober / november perhaps. so still time to overthink things |
Starting problems 4-AGE kouki | Hanzo | 3 | 2,722 |
Question about camshaft | CHACAMAN | 2 | 3,708 |
07-07-2020 06:41 PM Last Post: oldeskewltoy |
Camshaft ID | kazi | 6 | 7,699 |
09-26-2018 12:07 AM Last Post: oldeskewltoy |
Anyone farmiliar with hks camshaft types for 4age? | spill86 | 5 | 16,127 |
11-18-2017 11:36 PM Last Post: oldeskewltoy |
Camshaft sprocket bolt size? | harkes | 1 | 4,681 |
07-03-2015 12:41 PM Last Post: Dave W |
