4 age smallport cams
07-24-2007, 06:25 PM
Here´s another one who likes to change his cams. Sorry to bother all you guys with another cam question
Small port 4 age with throttle bodies. Omex ECU. 280cc injectors. Now using standard cams in and exhaust side 232 degrees and 7.1 mm lift. would like to keep it a non interferance engine too Not looking for peak power but midrange. Don not want to loose lower end torque too much.256 / 264 something like that. but lift ? it should idle "normal"... Does anybody has any experiences with catcams.be ? cheers Jos http://www.heerlijklimburg.nl |
07-25-2007, 08:22 AM
ive heard blue top cams make some difference to power in a smallport. have to be re-shimmed though.
07-26-2007, 07:23 PM
thank you for your tip.
nice country to be livin :wink: http://www.heerlijklimburg.nl |
07-26-2007, 08:43 PM
not so much in winter. summers are pretty nice though
dancke. |
07-26-2007, 09:17 PM
catcams are ok haven't felt it yet with itb's (soon will building an engine) But with standard intake the high lift kill the lower rpm.
10-18-2007, 07:46 AM
Dear Robokill,
Have you made any progress yet ? Since the 4age is a non interferance engine I want to keep it that way, so what cams are max. to keep it non interferance ? ( would like to change them before it gets dyno'd maybe, to take some more advantage of the tb's without losing to much on lower rpm ) regards Jos http://www.heerlijklimburg.nl |
Smallport coil | totta Crolla | 2 | 1,793 |
08-12-2022 11:03 AM Last Post: totta Crolla |
Smallport inlet manifold | totta Crolla | 6 | 3,508 |
01-17-2022 05:14 PM Last Post: oldeskewltoy |
Starting problems 4-AGE kouki | Hanzo | 3 | 2,684 |
Shim size for AM cams | kazi | 4 | 5,253 |
4A-GTE 7-rib smallport | nyberrg | 5 | 6,294 |
05-24-2017 09:24 PM Last Post: krullibull |
