4AC and 4AG transmission the same
03-19-2005, 07:37 PM
Is the 4AC transmission the same as the 4AG? Will the 4AC bolt up to the 4AG motor?
You have by far the ugliest hachi on the nicest rims in the world -Mux213
03-19-2005, 07:44 PM
the transmission is the same BUT you must replace the bellhousing whit a 4age bellhousing Thumbs up!
[Image: AEU86 AE86 - 4AC and 4AG transmission the same]
03-19-2005, 08:34 PM
I believe the slave is different as well. You should be able to reuse the fork.
Broken down 1984 Trueno HB
03-19-2005, 10:25 PM
I thought the bellhousing was the same but the slave was on the wrong side.
03-19-2005, 11:53 PM
The slave is on the other side...why....because the fork is on that side. Meaning the hole is on the other side. It's the same, but left is right etc.
03-20-2005, 12:07 AM
Well I have a FWD 4AG and the starter is on the left and the slave is on the right, just like the 4AC.
03-20-2005, 10:36 AM
The slave is on the other side - reason: exhaust tubes. No problem to use 4AC belhousing if you take care of exhaust tubes.
03-20-2005, 12:54 PM
Mulisha Wrote:Well I have a FWD 4AG and the starter is on the left and the slave is on the right, just like the 4AC.
a FWD starter will not fit your RWD bellhousing. Sad
Punky's Corner
03-20-2005, 08:42 PM
crap. Ok you guys win, as always Sad
  Question about 4AG 20v Engine Block CHACAMAN 1 1,780 06-10-2022 05:17 PM
Last Post: oldeskewltoy
  Gearbox mount and transmission mount gh0st 9 3,841 05-08-2022 03:28 PM
Last Post: totta Crolla
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 11,698 02-10-2020 06:39 PM
Last Post: Power_uP
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 4,379 11-05-2016 01:34 AM
  4ac gearbox on 4age hachirokkos 2 6,519 05-24-2016 10:16 PM
