4AC and 4AG transmission the same
03-19-2005, 07:37 PM
Is the 4AC transmission the same as the 4AG? Will the 4AC bolt up to the 4AG motor?
You have by far the ugliest hachi on the nicest rims in the world -Mux213 |
03-19-2005, 07:44 PM
the transmission is the same BUT you must replace the bellhousing whit a 4age bellhousing
![]() ![]() sr86 completed!!........漂うことのマスター!!!! |
03-19-2005, 08:34 PM
I believe the slave is different as well. You should be able to reuse the fork.
Broken down 1984 Trueno HB ![]() |
03-19-2005, 10:25 PM
I thought the bellhousing was the same but the slave was on the wrong side.
03-19-2005, 11:53 PM
The slave is on the other side...why....because the fork is on that side. Meaning the hole is on the other side. It's the same, but left is right etc.
03-20-2005, 12:07 AM
Well I have a FWD 4AG and the starter is on the left and the slave is on the right, just like the 4AC.
03-20-2005, 10:36 AM
The slave is on the other side - reason: exhaust tubes. No problem to use 4AC belhousing if you take care of exhaust tubes.
03-20-2005, 12:54 PM
Mulisha Wrote:Well I have a FWD 4AG and the starter is on the left and the slave is on the right, just like the 4AC. a FWD starter will not fit your RWD bellhousing. ![]() Punky's Corner |
03-20-2005, 08:42 PM
crap. Ok you guys win, as always
![]() You have by far the ugliest hachi on the nicest rims in the world -Mux213 |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,814 |
Gearbox mount and transmission mount | gh0st | 9 | 3,905 |
05-08-2022 03:28 PM Last Post: totta Crolla |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 11,844 |
Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 4,408 |
4ac gearbox on 4age | hachirokkos | 2 | 6,592 |
05-24-2016 10:16 PM Last Post: banpei |
User(s) browsing this thread:
