4AC block with 4AG head
08-13-2005, 07:20 AM
I know this is possible. I think. What generation 4ag head can I use? I know ill have to do something about the exhaust. Ill keep it carbed, for now. Cna I just rip the head out of an AE92 and put it on my SR5?
Sniper
1986 Toyota Corolla SR5
1989 BMW 535i
1986 Volvo 740 GLE
08-15-2005, 07:11 AM
This sounds interesting!
08-15-2005, 07:27 AM
Yeah Ive researched this on CLub4AG, its possible. I just dont know if it be quicker to swap engines...because I dont want to decommission my car for a few days, even though its not my daily driver
I heard that Id need the 4AG internals and a 4AG gasket although I heard someone say they were the same....
Sniper
1989 BMW 535i
1986 Volvo 740 GLE
08-15-2005, 08:25 AM
so what i know you need also change the pistons, an engine swap its quickierSmile
http://www.86ers.org
08-15-2005, 08:34 AM
Yeah, if the internals need to be changed then I would say it would be quicker to do a engine swap with the 4AGE....and you prob would get more power.
It would be interesting to see a conversion like what your talking about, though.
08-15-2005, 09:08 AM
thats where the transmission bellhousing problem comes in, cant find a GTS bellhousing
Sniper
1989 BMW 535i
1986 Volvo 740 GLE
08-15-2005, 09:27 AM
The belhousing is NOT a problem.
You can also use 4AFE internals - widely available, not weaker than early 4AGE ones - the crank will match your 4AC flywheel. You must check carefully CR and valve-piston clearances.
08-15-2005, 10:01 AM
So I can use a 4AGE with my SR5 transmission?
When I do find a 4AG engine, ill keep it carbed, then maybe later get the EFI goin'. if thats possible
Sniper
1989 BMW 535i
1986 Volvo 740 GLE
08-15-2005, 10:27 AM
SniperGT Wrote:So I can use a 4AGE with my SR5 transmission?
Yes, you can.
When you find 4AGE, try to buy harness and EFI also from the same car- this is the straight (and easiest) swap.
  Question about 4AG 20v Engine Block CHACAMAN 1 1,751 06-10-2022 05:17 PM
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 11,511 02-10-2020 06:39 PM
Last Post: Power_uP
  4AGE block differences explained (incl. some eyecandy) Bean 46 89,276 05-05-2019 04:03 AM
Last Post: Rocker100
  BT head with ST block. CHOPKIN2 6 7,392 02-06-2018 06:27 PM
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 4,362 11-05-2016 01:34 AM
