4AC block with 4AG head
08-13-2005, 07:20 AM
I know this is possible. I think. What generation 4ag head can I use? I know ill have to do something about the exhaust. Ill keep it carbed, for now. Cna I just rip the head out of an AE92 and put it on my SR5?
Sniper ----------------------------- 1986 Toyota Corolla SR5 1989 BMW 535i 1986 Volvo 740 GLE ----------------------------- |
08-15-2005, 07:11 AM
This sounds interesting!
I once read that you shouldnt believe everything you read. |
08-15-2005, 07:27 AM
Yeah Ive researched this on CLub4AG, its possible. I just dont know if it be quicker to swap engines...because I dont want to decommission my car for a few days, even though its not my daily driver
I heard that Id need the 4AG internals and a 4AG gasket although I heard someone say they were the same.... Sniper ----------------------------- 1986 Toyota Corolla SR5 1989 BMW 535i 1986 Volvo 740 GLE ----------------------------- |
08-15-2005, 08:25 AM
so what i know you need also change the pistons, an engine swap its quickier
http://www.86ers.org All the hachies that Daytona can only dream about. |
08-15-2005, 08:34 AM
Yeah, if the internals need to be changed then I would say it would be quicker to do a engine swap with the 4AGE....and you prob would get more power.
It would be interesting to see a conversion like what your talking about, though. I once read that you shouldnt believe everything you read. |
08-15-2005, 09:08 AM
thats where the transmission bellhousing problem comes in, cant find a GTS bellhousing
08-15-2005, 09:27 AM
The belhousing is NOT a problem.
You can also use 4AFE internals - widely available, not weaker than early 4AGE ones - the crank will match your 4AC flywheel. You must check carefully CR and valve-piston clearances. |
08-15-2005, 10:01 AM
So I can use a 4AGE with my SR5 transmission?
When I do find a 4AG engine, ill keep it carbed, then maybe later get the EFI goin'. if thats possible Sniper ----------------------------- 1986 Toyota Corolla SR5 1989 BMW 535i 1986 Volvo 740 GLE ----------------------------- |
08-15-2005, 10:27 AM
SniperGT Wrote:So I can use a 4AGE with my SR5 transmission?Yes, you can. When you find 4AGE, try to buy harness and EFI also from the same car- this is the straight (and easiest) swap. |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,580 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 10,831 |
4AGE block differences explained (incl. some eyecandy) | Bean | 46 | 86,481 |
05-05-2019 04:03 AM Last Post: Rocker100 |
BT head with ST block. | CHOPKIN2 | 6 | 7,082 |
02-06-2018 06:27 PM Last Post: mad.matt |
Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 4,254 |
