4AGE 16V engine overheat when at high speed
11-07-2020, 10:29 PM
Post: #31
Ugh! That looks gross!
Great to hear you found it! 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
11-14-2020, 10:41 PM
Post: #32
How did you dismantle the radiator and then put it back together again?
12-31-2020, 06:39 AM
Post: #33
(11-14-2020 10:41 PM)decryphe Wrote: How did you dismantle the radiator and then put it back together again? My apologies for late reply. I bought a small size "utility Plier" and do small modification at tip area with angle grinder. The front end grinded as below photo This piers is to dismantle the radiator cover. To put it back just use a standard "adjustable locking plier" Tq |
| High-beam warning lamp | Mylesmck | 4 | 3,114 |
| Engine stress at high speeds | gh0st | 6 | 4,502 |
| Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 24,379 |
| 4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 10,146 |
| AE86 4A-GE 16v engine harness rebuild | FanIsHere | 7 | 13,350 |
![AEU86 AE86 - 4AGE 16V engine overheat wh...high speed [Image: AEU86 AE86 - 4AGE 16V engine overheat wh...high speed]](https://www.aeu86.org/sticker-banner-468.gif)
