4AGE 16v injectors physical size
10-07-2010, 11:20 AM
Hi
Does someone know what are physical size of injectors that fit between 4AGE head and fuel rail ?
I know tehnical spec from service manual:
Resistance : 1.5-3.0 ohm
Injector Volume : 49 - 56 cc/15 sec (3.0 - 3.4 cu in.)
Difference Between Each Injector : Less than 5 cc (0.31 cu in.)
Fuel Leakage : Less than one drop of fuel per minute
But need dimensions. Lenght, diameter of rings...
I have them on my engine, but I would like to spare myself some time Smile
Thanks
10-07-2010, 12:58 PM
I can give you all the size you need this afternoon after my work :wink:
just tell me what you are looking for.
10-07-2010, 01:57 PM
I need (at least Smile) these dimensions:
[Image: AEU86 AE86 - 4AGE 16v injectors physical size]
Thanks!
10-07-2010, 11:23 PM
A: 16mm
B: 24mm
C: 11mm
D: 73mm
E: ~63mm
10-08-2010, 09:10 AM
Great, thanks! Smile
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 20,431 05-01-2021 10:09 PM
  4AGE 16V engine overheat when at high speed chenfon 32 20,917 12-31-2020 06:39 AM
Last Post: chenfon
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 7,160 11-09-2020 10:51 AM
Last Post: totta Crolla
  Shim size for AM cams kazi 4 5,107 12-18-2017 05:34 PM
Last Post: oldeskewltoy
Wink Hub size kazi 5 9,507 06-09-2017 10:06 PM
Last Post: kazi
