4AGE 16v injectors physical size
10-07-2010, 11:20 AM
Hi
Does someone know what are physical size of injectors that fit between 4AGE head and fuel rail ? I know tehnical spec from service manual: Resistance : 1.5-3.0 ohm Injector Volume : 49 - 56 cc/15 sec (3.0 - 3.4 cu in.) Difference Between Each Injector : Less than 5 cc (0.31 cu in.) Fuel Leakage : Less than one drop of fuel per minute But need dimensions. Lenght, diameter of rings... I have them on my engine, but I would like to spare myself some time Thanks |
10-07-2010, 12:58 PM
I can give you all the size you need this afternoon after my work :wink:
just tell me what you are looking for. |
10-07-2010, 01:57 PM
I need (at least
) these dimensions:![]() Thanks! |
10-07-2010, 11:23 PM
A: 16mm
B: 24mm C: 11mm D: 73mm E: ~63mm |
10-08-2010, 09:10 AM
Great, thanks!
| 4AGE Injectors resistor | Blaze0010 | 4 | 2,388 |
01-27-2025 03:20 PM Last Post: Bean |
| Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 24,387 |
05-01-2021 10:09 PM Last Post: Ivan141 |
| 4AGE 16V engine overheat when at high speed | chenfon | 32 | 31,456 |
| 4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 10,162 |
| Shim size for AM cams | kazi | 4 | 6,644 |
![AEU86 AE86 - 4AGE 16v injectors physical size [Image: AEU86 AE86 - 4AGE 16v injectors physical size]](https://lh6.ggpht.com/_APKI3b0oh_A/TK25zvseUQI/AAAAAAAADkg/-IhPcJZNANY/s800/MOTR-04655-dimensions_a.jpg)
