4AGE 16v injectors physical size
10-07-2010, 11:20 AM
Hi
Does someone know what are physical size of injectors that fit between 4AGE head and fuel rail ? I know tehnical spec from service manual: Resistance : 1.5-3.0 ohm Injector Volume : 49 - 56 cc/15 sec (3.0 - 3.4 cu in.) Difference Between Each Injector : Less than 5 cc (0.31 cu in.) Fuel Leakage : Less than one drop of fuel per minute But need dimensions. Lenght, diameter of rings... I have them on my engine, but I would like to spare myself some time Thanks |
10-07-2010, 12:58 PM
I can give you all the size you need this afternoon after my work :wink:
just tell me what you are looking for. |
10-07-2010, 01:57 PM
I need (at least ) these dimensions:
Thanks! |
10-07-2010, 11:23 PM
A: 16mm
B: 24mm C: 11mm D: 73mm E: ~63mm |
10-08-2010, 09:10 AM
Great, thanks!
Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 20,431 |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 20,913 |
4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 7,160 |
Shim size for AM cams | kazi | 4 | 5,107 |
Hub size | kazi | 5 | 9,507 |
06-09-2017 10:06 PM Last Post: kazi |
