4AGE block differences explained (incl. some eyecandy)
02-22-2013, 10:51 AM
Post: #41
Did my engine ever feature in an AE92?
02-22-2013, 01:47 PM
Post: #42
Alex170984 Wrote:Did my engine ever feature in an AE92?
probably, one from the early years.
04-08-2013, 08:47 PM
Post: #43
I've found a block with the following specs:
- 7 Rib block
- 40mm crankshaft
- no extra-meat
- 10:1 pistons w/o the sublevel
What may be the origin of this block? Seems that its mixed up and it's a transition block....
01-04-2014, 09:42 PM
Post: #44
Its a late hybrid 4age bigport engine i think.
Finally got arround to disassembling my engine which happens to be the same:
Its a 4age red and black letters september 1986 belgium 7 rib engine
270 000 kms on of which 15000km on circuit
-7 rib block
-40 mm crankshaft
-18 mm pins
-10:1 pistons
pictures
[Image: AEU86 AE86 - 4AGE block differences expl... eyecandy)]
05-01-2019, 11:55 PM (This post was last modified: 05-02-2019 05:46 AM by Rocker100.)
Post: #45
Revive the Ancient thread! I'd love to see those pictures, that are no longer hosted. I believe I have the same engine in an American AE92.
05-02-2019, 03:52 PM
Post: #46
(05-01-2019 11:55 PM)Rocker100 Wrote:  Revive the Ancient thread! I'd love to see those pictures, that are no longer hosted. I believe I have the same engine in an American AE92.
Not likely... but in 30 (+ or -) years just about anything is possible
have you opened up your engine yet? look at the pistons..... take a photo, and share it with us.........
Dan -
05-05-2019, 04:03 AM
Post: #47
I'm sure it's original equipment. The car has 199k miles, I haven't cracked it open yet. I have rebuilt the distributor, and fixed some other oil leaks. The most I've done is the valve cover gaskets. This weekend I'm thinking about doing the front crank seal, and my original concern was if there were variations in crank seal diameters between bigport generations. I guess I'll find out tomorrow or Monday. Or I might wait until I have the belt and water pump. Thanks for the reply. If I find anything odd I'll put it up here.
  Question about 4AG 20v Engine Block CHACAMAN 1 1,589 06-10-2022 05:17 PM
  Clutch differences LUK vs Exedy r.ave 2 4,991 05-27-2021 09:30 AM
Last Post: r.ave
  BT head with ST block. CHOPKIN2 6 7,119 02-06-2018 06:27 PM
  How important are dowell pins on a 4age block spill86 5 7,510 01-13-2016 11:19 AM
Last Post: spill86
  7 rib block for a bluetop head? dinkers542 7 9,612 11-04-2014 01:44 PM
Last Post: zenki
