4AGE ignition problem
07-30-2007, 01:04 PM
Hi!
I need help. I have a 4AGE engine corolla. This runs like a 2-cylinder and 3-cylinder engine. This is alternating
periodically. The spark plugs and cables are good. I can rise the rpm to 6000 smoothly. But if I push the
accelerate fast, the engine's always knocking. I've already check the Ne and G signals. They look good, but I don't
know if the timing is good or not. The ECU sends the IGt signal to the igniter, but the IGf signal is not perfect.
This should be like a "shark-fluke". It has, but this is about 1V amplitude and it has a 12V square-wave at the falling-edge.
I can send picture if you send me e-mail address to my [email protected] mailer.
What can I do or check?
Sincerely,
Istvan Torma from Hungary
07-31-2007, 10:04 AM
If the engine is knocking (= pinking) then your ignition is too far
advanced for the octane rating of your fuel. Retard the timing until
the knocking goes away. Then see what symptoms remain.
Cheers... jondee86
  Ignition switch plug and wires Blaze0010 3 472 11-25-2024 12:29 PM
Last Post: Blaze0010
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,807 07-18-2019 03:52 PM
Last Post: oldeskewltoy
  extracted freedom ecu 16v ignition map ditn 7 9,095 08-22-2016 10:01 AM
Last Post: ditn
  4AGE 20v Ignition Lead Length mad.matt 3 6,772 10-01-2014 03:43 PM
  [Tutorial Video] Setting 4A-GE Ignition Timing Homem Bomba 0 5,575 04-21-2014 02:41 PM
Last Post: Homem Bomba
