4AGE ignition problem
07-30-2007, 01:04 PM
Hi!
I need help. I have a 4AGE engine corolla. This runs like a 2-cylinder and 3-cylinder engine. This is alternating periodically. The spark plugs and cables are good. I can rise the rpm to 6000 smoothly. But if I push the accelerate fast, the engine's always knocking. I've already check the Ne and G signals. They look good, but I don't know if the timing is good or not. The ECU sends the IGt signal to the igniter, but the IGf signal is not perfect. This should be like a "shark-fluke". It has, but this is about 1V amplitude and it has a 12V square-wave at the falling-edge. I can send picture if you send me e-mail address to my [email protected] mailer. What can I do or check? Sincerely, Istvan Torma from Hungary |
07-31-2007, 10:04 AM
If the engine is knocking (= pinking) then your ignition is too far
advanced for the octane rating of your fuel. Retard the timing until the knocking goes away. Then see what symptoms remain. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
Ignition switch plug and wires | Blaze0010 | 3 | 1,195 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 15,023 |
extracted freedom ecu 16v ignition map | ditn | 7 | 10,131 |
4AGE 20v Ignition Lead Length | mad.matt | 3 | 7,343 |
[Tutorial Video] Setting 4A-GE Ignition Timing | Homem Bomba | 0 | 6,033 |
