4age 16v 1st and 2nd generation cams and not only difference
09-15-2013, 04:28 PM
hello mates
i own an ae92 hatch gti (eupopean specs) 2nd gen engine 3/1988
i believe that i have the 232 degrees cams that on of the basic difference from the 1st gen 4age.
i know that i have the piston with 10.1 compression cause i have rebuilded the motor recently....
so my question is the 1st gen was more powerfull with the 240 cams?
4age 16v to FR 20VT
09-15-2013, 10:18 PM
Apsogos Wrote:so my question is the 1st gen was more powerfull with the 240 cams?
not really..... a lot of it it has to do with dynamic compression ratio... some call it "trapped compression"
Note how toyota did not evenly change the cam timing, but they removed 7 of the 8 degrees from the point the intake valve closes.
[Image: AEU86 AE86 - 4age 16v 1st and 2nd genera...difference]
Dan -
09-16-2013, 08:24 AM
so i try to figure out....in my engine that is properly rebuilded with compression about 10.6 , a new free flow exhaust system a better air intake filtering system,an 20v header ,european specs, if i install the 240 cam , will i gain more power?
P.S
The blutop 1st gen was performing the same power with 2nd Gen tvis ae92 engines?
4age 16v to FR 20VT
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 20,614 05-01-2021 10:09 PM
  Help me AEU86, you're my only hope Nakilad 38 15,714 04-10-2021 05:19 PM
Last Post: Nakilad
  4AGE 16V engine overheat when at high speed chenfon 32 21,339 12-31-2020 06:39 AM
Last Post: chenfon
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 7,272 11-09-2020 10:51 AM
Last Post: totta Crolla
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 17,247 08-16-2018 01:36 AM
