4age bogs. Would like some help!
12-28-2009, 03:49 AM
I just rebuilt a stock 4AGE and it wants to bog just as I give it throttle?
It idles well and runs fine if I keep the rev's high (no bog at start).
But when I start from idle it always hesitates then goes fine?
Anybody have suggestions what might cause this or info on where to look first? I'd like to get some info on timing advance?
Is there a good source available for tuning basics?
12-28-2009, 01:06 PM
Grab yourself the factory manual from the aeu86 main site, all basics and everything else are covered in it.
It's likely to be some electrical problem.
It might be the AFM sensor that's died ore some air leak behind it.
12-30-2009, 09:02 AM
Total timing advance is handled by the ECU, but you do have to make
sure the base timing (10 deg BTDC) is set correctly. The procedure is
set down in the FSM.
If the hesitation is relatively minor, you could check the adjustment
of the idle switch in the TPS. That switch is responsible for signaling the
ECU to change from "idle" settings to "run" settings, and if not adjusted
correctly, will interfere with the on throttle/off throttle transition. Again,
the procedure is set down in the FSM.
Cheers... jondee86
12-30-2009, 11:10 AM
Double check that you have no vacuum air leaks
  Some wiring help needed DJexor 5 5,448 05-18-2019 01:50 PM
Last Post: DJexor
  4AGE block differences explained (incl. some eyecandy) Bean 46 87,256 05-05-2019 04:03 AM
Last Post: Rocker100
  Need some help DJexor 4 5,326 03-13-2018 05:37 PM
Last Post: pack
  How would/have you rebuild your 4age? joaotcgt 6 8,928 07-21-2015 10:40 AM
  Removing unnecessary wires.. some identification help! 4000GT 3 5,057 08-20-2011 04:40 AM
Last Post: 4000GT
