4age oil pan + cooler to a 4AGZE ?
09-07-2011, 10:27 PM
Hey die hard tech nutz
![]() I need help on this as I couldn't find anything at all on the interwebz... I have a GZE in my AE right now and I need to grab the bottom oil-pan (Carterpan) and put it on the GZE But how does it work and where do I fit the oil cooler? Does the oil-pan need a new gasket? Please help me out - all help is welcome - thanks in advance again guys! -DWG- Drift Wolf Gaming |
09-07-2011, 10:34 PM
I do believe I used liquid gasket on oil pans in the past...shouldnt be a problem (it needs a gasket!).
Oil cooler goes between the sandwich plate under the oil filter and the return pipe on the oilpan. If you cant find them, chances are you dont have them or need to transfer them from your old engine. FABRICA MI DIEM, PVNC! |
09-07-2011, 10:52 PM
Thanks Ivan
If more people wanna brush up on this you're more than welcome. Pics might also be nice if people have done this in real life ![]() Thanks -DWG- Drift Wolf Gaming |
09-08-2011, 08:24 AM
hey mate,
in my case it was like ivan said, i had to use the oilpan and sandwichplate from 4AGE to fit it my GZE, everything is plug an play. greets |
09-08-2011, 10:20 AM
swap oilpan and sandwichplate with new gasket and o-ring
and connect your cooler on it ![]() '87 levin coupé ![]() |
09-08-2011, 02:56 PM
I would take an aftermarket sandwich plate with thermostat and a new oil cooler. The original setup is not very effective so a full flow setup would be a great improvement
![]() Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
Mocal oil cooler & sandwitch plate ordered | Gtsi-R | 48 | 61,314 |
Oil cooler | totta Crolla | 0 | 1,932 |
07-25-2021 03:25 PM Last Post: totta Crolla |
Oil cooler kit | izanagi | 7 | 9,597 |
09-20-2016 11:13 AM Last Post: harkes |
Oil Pan Issue | Alex170984 | 6 | 7,658 |
01-11-2016 04:50 PM Last Post: Alex170984 |
Permanent oil cooler vs thermostat | Lt86 | 19 | 23,196 |
03-28-2015 06:54 PM Last Post: Lt86 |
