4age problem
12-13-2008, 10:17 PM
4age problem
i have 85 ae86 gts that accelerates poorly. i went to get it repaired to pass smog because i live in ca usa. the timing was set back to 10 btdc. it idles smooth and it passes smog now but accelerates really slow. when the timing was at 15 btdc it pulled strong but ran rough. the crank pulley and cam gears all line up. i'm about to replace the vacuum hoses around the intake even though they look alright. i ran the cel diagnostic and "normal" code comes up. i heard it might be a compression problem or an electrical problem.
any suggestions?
cheers mates Thumbs up!
12-14-2008, 11:27 AM
4age problem
Make sure the timing was set with the diagnostic terminals bridged (to set the timing to static mode).
  4agZe problem solved - 99% IC problem Okami 41 37,611 07-12-2012 04:49 PM
Last Post: Okami
  4age idle/fuel problem Alex 7 10,026 06-24-2011 09:07 PM
Last Post: Alex
  [4AGE] ignition timing problem -> SOLVED !! eg6maxx 16 50,597 05-17-2011 11:48 AM
Last Post: eg6maxx
  Carb'd 4AGE on Hyperpak ignition no spark problem 4AGE FORD 12 24,102 01-22-2011 11:03 PM
Last Post: 4AGE FORD
  AC problem? Idle problem? KD2229 3 4,983 08-19-2009 02:08 AM
Last Post: KD2229
