4age turbo
07-17-2009, 01:59 PM
4age turbo
what turbo shud I use with stock interns? I was thinking to buy a T20 or a T25?
wil I be needing a Additional Injector Controller? |
09-02-2009, 11:34 PM
4age turbo
i have a t25 now and i am going 0.4bar with stock interns
09-02-2009, 11:43 PM
4age turbo
the T25 is the better turbo for a stock 4age
it will be on full boost whene the Tvis open SR Team BURN THE RUBER NOT YOUR SOUL! |
09-03-2009, 04:19 PM
4age turbo
were do i take my oil for the turbo?
I was thinking to take out the oil pressure regulator from the oil cooler and install there the oil system. do I have sufficient pressure there? does it effect the cooling system? |
09-03-2009, 06:41 PM
4age turbo
pls help... I need to finish the car in time for KOE
09-03-2009, 06:42 PM
4age turbo
I hope this will help. http://www.hachiroku.com.au/blog/?p=2285
Vladimir N/A for life... |
09-03-2009, 08:17 PM
4age turbo
can't find information about the oil system to the turbo.
09-03-2009, 10:29 PM
4age turbo
you can tap the hole used for the pressure sensor, just ad a T fitting and route the oil to the turbo.
09-04-2009, 12:03 AM
4age turbo
are you sure...won't there be less pressure?I mean , is there enough oil pressure for the cooler and also for turbo ?
09-04-2009, 03:49 AM
4age turbo
Usualy (all the conversion post that i have read) Taked the oil for the turbo From the stock oil press sensor
Whil you've add a new sensor ... the stock one became useless... SR Team BURN THE RUBER NOT YOUR SOUL! |
whats the crack with 16v turbo? | kazi | 5 | 6,020 |
08-02-2017 12:15 AM Last Post: kazi |
Bluetop on turbo | leon205gti | 7 | 7,712 |
09-20-2016 09:17 PM Last Post: leon205gti |
can i just slam a oem turbo on it ? | MC_JP | 3 | 5,897 |
12-17-2014 11:04 PM Last Post: oldeskewltoy |
4age stock bigport on turbo | leon205gti | 8 | 16,277 |
01-17-2014 01:02 PM Last Post: leon205gti |
4AGTE turbo manifold questions | daveskatesallday | 3 | 4,854 |
08-13-2013 07:38 PM Last Post: daveskatesallday |
