5.375 final drive ratio with stock T50
08-06-2012, 10:58 AM
I did consider that, and asked Leen about it, but they have not made the paddle shift yet. If its priced anything like their conversion kit, I wouldnt be interested it would be cheaper buying a sequential box!
08-06-2012, 12:25 PM
ok where does your engine make peak power and where does it drop off also how much power as well
08-06-2012, 12:34 PM
You are properbly right about the price. It is a really nice kit, though
![]() Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
08-07-2012, 07:04 AM
Celica RA45 Wrote:ok where does your engine make peak power and where does it drop off also how much power as well Peak power is 175WHP, at slightly over 9,000rpm (from memory on the rpm). |
Jan Pedersen Wrote:You are properbly right about the price. It is a really nice kit, though Yeah I bet its an awesome kit! On the positive note, Weir Performance have made a 5.13 final drive and will be priced under USD400. Thats a good deal. |
08-07-2012, 08:12 AM
what you can do is make the ram tubes longer ,which will pick up mid range and make max power at 8500 instead of over 9
can get trd gear kit for 3k landed here in oz all the 4 gears etc |
08-07-2012, 09:33 AM
The ram tubes cant physically be any longer, unless I grab a tilton or wilwood pedal box and run remote master cylinders. Really I should put money aside for a sequential box and do it properly.
08-07-2012, 09:55 AM
you can always put curved 1s on
![]() ![]() to give you an idea |
08-07-2012, 10:53 AM
I am actually running a plenum...
Here is the motor spec Custom header (SS 304 in 1.5" diameter primaries and 660mm long, to a full 2.5" SS 304 exhaust, DEI header wrap Custom Aluminium intake with CNC backing plate with built in 45mm velocity stacks. 3SGTE injectors Coil On Plug ignition Sliver top block (I grenaded a Black Top one) with balanced crank, ARP Bolts throughout, ACL bearings, Tomei rods, custom CP pistons, 15:1 CR. 288 degree 10mm lift Kelford Cams Supertech 1mm OS valves, Supertech Valve Springs Excedy Lightweight Flywheel Setrab oil cooler and TRD oil filter with HKS adapter off the block Moroso catch can (shortened to meet regs) with K&N filter Half size radiator with alloy shrouding and electric fan K&N 4" cone filter TRD 0.8mm headgasket |
08-07-2012, 11:49 AM
similar to group A specs
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,527 |
T50 gearbox | totta Crolla | 3 | 2,634 |
02-25-2022 02:35 PM Last Post: Project D |
82mm Stock compression Pistons | apardal | 4 | 2,948 |
T50 TRD gearset | DidiDex | 7 | 9,243 |
09-12-2019 07:36 PM Last Post: DidiDex |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 13,805 |
