86mm piston wizards...
05-18-2017, 12:00 PM
Heya people, wondering if anyone has a tip on 86mm pistons to suit a 1uzfe. Long story but before I get some pistons custom made, thought I would extend the question Smile
Cheers lads
Sent from my HTC 2PS6200 using Tapatalk
clutch kick, switch, tree .... oowwww
05-19-2017, 08:05 AM
stock CR or higher?
Sent from my SM-T800 using Tapatalk
AE86 ex-daily
05-21-2017, 12:56 PM
A touch higher is fine but nothing over 11to1.
05-21-2017, 10:30 PM (This post was last modified: 05-21-2017 10:34 PM by Bean.)
OEM? also a quick google came up with this http://www.xatracing.com/cpfopikit1uz.html seems reasonable for a set of 8
AE86 ex-daily
05-21-2017, 11:26 PM
I think the problem here is that the 1UZ-FE has a stock bore size
of 87.5mm and the OP is looking for stock 86.0mm pistons from some
other engine series that he could use in a 1UZ-FE that has been sleeved
down to 86.0mm bore size.
Undersized pistons are not in big demand Smile
Cheers... jondee86
05-22-2017, 09:12 AM
I see now things make sense. Have a look at SR20 pistons, they come in all varieties and the common DE engine has a CR of 9.5 Pin diameter is around 22mm so should fit too. Just check that the compression height isn't too far off.
AE86 ex-daily
05-30-2017, 02:36 PM
1UZ small end bushing is the same P/N as a 3S-GE engine from '97 onwards(SW20, ST21# and SXE10) and a 3S bore is 86mm.
  Piston ID kazi 5 5,523 08-11-2019 03:34 PM
Last Post: totta Crolla
  Piston Identification Alex170984 3 5,367 05-17-2016 12:47 PM
Last Post: Alex170984
  Piston availability totta Crolla 3 5,521 09-03-2015 09:32 PM
Last Post: oldeskewltoy
  which piston is this? ditn 10 12,092 07-04-2014 03:18 PM
  piston dome cc figure Bean 6 14,595 02-13-2013 03:24 PM
Last Post: jdm86gtz
