86mm piston wizards...
05-18-2017, 12:00 PM
Heya people, wondering if anyone has a tip on 86mm pistons to suit a 1uzfe. Long story but before I get some pistons custom made, thought I would extend the question
Cheers lads Sent from my HTC 2PS6200 using Tapatalk clutch kick, switch, tree .... oowwww |
05-19-2017, 08:05 AM
stock CR or higher?
Sent from my SM-T800 using Tapatalk AE86 ex-daily |
05-21-2017, 12:56 PM
A touch higher is fine but nothing over 11to1.
05-21-2017, 10:30 PM
(This post was last modified: 05-21-2017 10:34 PM by Bean.)
OEM? also a quick google came up with this http://www.xatracing.com/cpfopikit1uz.html seems reasonable for a set of 8
05-21-2017, 11:26 PM
I think the problem here is that the 1UZ-FE has a stock bore size
of 87.5mm and the OP is looking for stock 86.0mm pistons from some other engine series that he could use in a 1UZ-FE that has been sleeved down to 86.0mm bore size. Undersized pistons are not in big demand Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
05-22-2017, 09:12 AM
I see now things make sense. Have a look at SR20 pistons, they come in all varieties and the common DE engine has a CR of 9.5 Pin diameter is around 22mm so should fit too. Just check that the compression height isn't too far off.
AE86 ex-daily |
05-30-2017, 02:36 PM
1UZ small end bushing is the same P/N as a 3S-GE engine from '97 onwards(SW20, ST21# and SXE10) and a 3S bore is 86mm.
Piston ID | kazi | 5 | 5,478 |
08-11-2019 03:34 PM Last Post: totta Crolla |
Piston Identification | Alex170984 | 3 | 5,332 |
05-17-2016 12:47 PM Last Post: Alex170984 |
Piston availability | totta Crolla | 3 | 5,490 |
09-03-2015 09:32 PM Last Post: oldeskewltoy |
which piston is this? | ditn | 10 | 11,976 |
07-04-2014 03:18 PM Last Post: Bean |
piston dome cc figure | Bean | 6 | 14,551 |
02-13-2013 03:24 PM Last Post: jdm86gtz |
