A little write-up to "Short stroke" mod
03-13-2005, 11:28 AM
Recently I started to modify my front struts - shortening of 30 mm, coilovers and more.
I want to share some techniques that can make our life easier :-)
1. You don't need an impact wrench to disassemble the strut. The upper spring hat must be fixed in vice and you can loose the top screw.
2. When the strut is disassembled - sometimes the strut insert cannot be extracted easily. The reason - broken seal on top of the insert (near the inner sleeve of the strut housing). Sometimes the insert goes out 2-part - I don't know why the strut insert was broken in my case.
3. Strut housing cuts. You can make the whole operation at once - using good machinist with lathe. The first cut must be right under the lower spring cap - the machinist can fix the housing in the lathe using the upper part of the housing (with the inner sleeve). Then he can remove the lower spring hat and shorten the remaining tube (with internal sleeve) by 30-40mm (up to you).
PS: I made the things much more harder way :-( My first cut wasn't using lathe and now I have problems with it - and must re-cut it by hand...
  TRD Short Shifter Rattle Noise, It's Normal? Mattolo 19 24,395 04-27-2024 10:04 PM
  Ae86 bulk head mod to fit hydrolic clutch? dinkers542 8 12,029 11-25-2014 09:21 PM
Last Post: dinkers542
  Short stroke suspension totta Crolla 12 17,798 10-13-2012 06:09 PM
Last Post: fax0815
  Interesting 20v cam cover mod banpei 3 9,991 05-31-2012 02:44 PM
Last Post: Kid Karola
  Trueno Conversion but with a little twist / question. Okami 16 18,237 05-19-2012 06:41 AM
Last Post: danielt
