AE85 axle dif hub to ae86??
04-24-2012, 08:29 PM
Hi guys. i want to ask something. i own a ae86 about 7 years for now.
![]() ![]() Today a friend of mine came and asked me to sell my diff., rear axles and all the stuff back down there. and he said he would give his ae85's stuff. so simply we would swap the back of our cars. he pays me good money (about 2000 dolars and he pays the swap too) he is offering a great money so i started to think to swap the dif axle hubs etc. but the ae85's part are good enough for a oem 86 or not? could they handle my 130 horses? would i a brake the axle or damage the dif?? i couldnt find any info and i need to learn as fast as i can. thanks ![]() |
04-25-2012, 12:32 AM
IIRC you´ll end up with drum brakes at the rear!
The diff itself should be the same, check on the aluminium tag on the firewall if it says "T" under "Trans/Axle on the AE85 its the same. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
04-25-2012, 10:27 AM
Do you have LSD diff ? AE85 don't have it.
Standard FD for AE86 is 4.3. Most common for AE85 is 4.1 You have disc brakes. AE85 have drums Halfshafts are different, also. 4AGE and rear axle is what makes AE86 over AE85. I wouldn't do that. |
04-25-2012, 09:29 PM
Uzelac Wrote:Do you have LSD diff ? AE85 don't have it. you are right but i ll sell the car to someone. so i would like to make some more money but dont want the guy to break it easly. |
04-28-2012, 02:18 PM
Quite probable the AE85 has an S series diff which has a smaller centre. If it has, you also need to swap the rear half of the tailshaft.
04-28-2012, 10:22 PM
Melo Wrote:you are right but i ll sell the car to someone. so i would like to make some more money but dont want the guy to break it easly. Than go for it, just make sure you tell interested buyer that your AE86 is really AE85.5 ![]() |
04-30-2012, 11:38 PM
Uzelac Wrote:Melo Wrote:you are right but i ll sell the car to someone. so i would like to make some more money but dont want the guy to break it easly. of course i ll tell but i just wanted to know if the sr5's dif. and axles can stand so much powwweeeerr(130 hp) ![]() |
AE86 rear axle weight | megabob | 11 | 20,413 |
Axle width | totta Crolla | 1 | 1,561 |
Ae85 swap 4age. | Minidaxman | 8 | 6,426 |
04-07-2021 10:16 PM Last Post: Minidaxman |
Rear axle options | Dino86 | 13 | 14,709 |
Hub size | kazi | 5 | 10,457 |
