AE86 5th gear too big RPM can be customized ?
06-26-2009, 09:54 PM
Hi guys i need some explanation i see that there is only maybe 200rpm difference between 4th and 5th gear on typical AE86 GT T50 transmission can that be customized to maintain lower RPM because when driving on highway it is just too much. In my case i drive not so speedy only around 100-110km/h enjoying the ride but in 120km/h for example you just have 4000rpm in my case.
85' AE86 GT coupe lifetime project since 2005 |
06-26-2009, 11:56 PM
You can change the input shaft ratio. The 5th gear is an overdrive gear and will be taller when you make the gearbox close ratio:
http://www.billzilla.org/drivetrn.htm 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
06-27-2009, 10:19 PM
i knoƧw that the compagny REVOLVER in Japan make a long ratio for the 5th gear.
But i can't get a link sorry. SR Team BURN THE RUBER NOT YOUR SOUL! |
06-27-2009, 11:23 PM
Why not fit a 4.1 crown wheel and pinion to your rear end , as your car will have a 4.3 from factory. I fitted a 4.1 to one of my road cars and it was very good to drive on the open road and around the city.
06-27-2009, 11:52 PM
Changing the fial drive will be the easiest and cheapest way to go.
You can also change the ratio of your gears. Revolver offers various ratios: http://www.revolver-jp.co.jp/products/drivegear.html If you need anything from there hit me up. Speed Industries Hurdnerwaeldlistr. 73 8808 Pfaeffikon Switzerland e-mail: [email protected] phone: +4155 420 15 69 page: http://www.speed-industries.ch MSN: [email protected] We have all the parts your Hachi needs |
Can Wing Mirror Glass be Replaced? | chrisae86 | 1 | 1,042 |
03-05-2023 09:34 PM Last Post: Ivan141 |
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,281 |
AE86 Driveshaft too long? [SOLVED] | MyCrazyGarage | 12 | 6,524 |
07-28-2022 10:48 PM Last Post: banpei |
Can you convert your 86 back too the original state? | gh0st | 7 | 2,608 |
04-25-2022 04:25 PM Last Post: gh0st |
Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 7,284 |
