AE86 Engine Coolant Temp Sensor
09-01-2014, 11:42 AM (This post was last modified: 09-01-2014 12:19 PM by izanagi.)
Re: RE: AE86 Engine Coolant Temp Sensor
(09-01-2014 09:07 AM)Ivan141 Wrote:  I'd expect the coolant sensor to be at the back of the head, but there are 2 (1 for the cluster, 1 to ecu), and I forgot where the other one is.
Also check your throttle valve adjustment, there is a screw adjustment on it with which you can set the valve opening @ closed throttle.
The screw is completely screwed and my idle is still high.
Envoyé depuis mon GT-I9100 avec Tapatalk
Messages In This Thread
AE86 Engine Coolant Temp Sensor - izanagi - 08-31-2014, 09:17 PM
Re: RE: AE86 Engine Coolant Temp Sensor - izanagi - 09-01-2014 11:42 AM
RE: AE86 Engine Coolant Temp Sensor - Bean - 09-01-2014, 05:09 PM
  Lambda sensor wiring sam3007 10 4,675 05-23-2022 10:00 PM
Last Post: The Doctor
  Hall sensor totta Crolla 7 8,435 02-28-2014 10:07 AM
  bad coolant kawo 9 11,497 11-18-2013 07:43 PM
Last Post: Apsogos
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 8,270 10-30-2013 11:18 PM
  Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE Homem Bomba 3 11,196 10-25-2013 05:13 PM
Last Post: Apsogos
