AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides
12-17-2013, 06:49 PM
Post: #411
jdm86gtz Wrote:I am looking for one with a much bigger volume to get an improvement over this:Jan Pedersen Wrote:Where do I get an air box like that for my 4AGE? It looks awesome! Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
06-09-2014, 11:56 PM
(This post was last modified: 06-10-2014 12:02 AM by Conrad.)
Post: #412
Update Time..... A few more bits and pieces but more importantly its ALIVE, it runs
Cutting out for the tailgate locks and fitted... Rear Quarter Window fitting Radiator modified to sit lower, pins welded on and brackets positioned Air / Water Separator Fabricated and fitted ...and here it is running on its very first start up.... (no exhaust system connected to the manifold) Click the picture I'm currently taking HRT ~ Hachi Roku Therapy |
06-10-2014, 10:45 AM
Post: #413
sounds nice, must feel good after so long
AE86 ex-daily |
06-10-2014, 11:33 AM
Post: #414
:thumbs:
Sounds great! 1985 AE86 (ハチロク) Levin - Summer time daily driver |
06-11-2014, 09:51 PM
Post: #415
That was a really good idea for the locks on the hatch. I might just steal that (idea ) from you.
11-26-2014, 04:06 PM
Post: #416
Ok here's the updates from a while ago....
Air box back plate and trumpets mounted. Air box fitted, lid retainer clips fitted also. Window slider, door handles, lock and window trims fitted. Rear window trims fitted, tailgate aero catches fitted. Hydraulic handbrake, cable handbrake setup The pedal box needed relocating for the master cylinder clearance against the bulkhead, this was achieved by water jet cutting a plate that mounted onto the original Tilton pedal set mounts on the chassis and then allowed the Tilton pedal set to be mounted on the plate 1" further forward. And mounted.... That's all for now folks, next up is to finish a few little odds and ends, map it on the dyno and then I will bring it home to finish off the other little stuff like sorting the hole on bulkhead, remount the chassis plate, air box intake hose and scoop, fit side skirts, fit rear bumper, fit front bumper, fit splitter and decide on final paint scheme etc I'm currently taking HRT ~ Hachi Roku Therapy |
12-16-2014, 04:27 PM
Post: #417
Well it's mapped, 195 ATW on Dyno Dynamics, holds power to 9000 rpm then it starts to taper away towards 9400rpm.
It's a lot less than I had hoped for, it would seem something's not working well together but for now let's just get it home, MOT'd, finish a few small bits and on get it on the road, it's only been 7 years :lol: I'm currently taking HRT ~ Hachi Roku Therapy |
12-16-2014, 10:49 PM
Post: #418
Stock cams ?
230+ engine hp? Sounds great if you ask me. |
12-17-2014, 12:10 PM
Post: #419
No mate, it has Toda Cams.
12-21-2014, 01:09 AM
Post: #420
will need to look at your dyno chart
ae86 racecar with beams engine | bakonick | 148 | 164,789 |
Krullibulls Ae86 BEAMS is the only way | krullibull | 86 | 89,273 |
Aram's 3SGE Beams Levin Coupe | robokill | 665 | 739,552 |
Beams Levin build | mannix20vt | 5 | 9,326 |
Another AE86, Duracell. Now with VEMS, and cage... | Uzelac | 62 | 88,770 |
