AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides
06-07-2015, 12:47 AM
Post: #421
I collected the 86 this week, it wasn't as complete as I had hoped for but that's another story. On a positive its home now and I can plod away over the next few months on a the jobs that are remaining.
Whilst I was out for the day collecting the 86 i nipped down to APT to collect the remaining drag Evo parts from breaking the car and took the opportunity to get the 86 4 wheel aligned which was one more job off the list.
Jobs left to do:
Fit front bumper
Fit rear bumper
Fit side skirts
Mount wiper motor
Terminate Loom at wiper motor
Identify loose core floating out of pdm plug
Fit bulkhead plate (where strut brace was welded on)
Fit air filter cone
Fit expansion tank overflow pipe
Fix paint blemishes and add final scheme colours
Fix bride seat cushion
Fit Tilton Remote brake bias
Finish dash beazel
Fit fuel temp sensor
Fit map sensor
Fit wheel speed sensors
Fit door mirror corner trims
Fabricate heal plate drivers side
Fabricate floor plate passenger side
Fit internal door mirror block trims
Modify exhaust ( needs raising )
[Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]
Q[Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]
I'm currently taking HRT ~ Hachi Roku Therapy Big Grin
06-07-2015, 01:07 AM
Post: #422
looking good, what does the weight pic include? I thought you'd be lighter than that despite the cage
06-09-2015, 09:03 PM
Post: #423
Wow! I like it a lot Dodgy.
Keep up the good work.
06-18-2015, 03:18 PM (This post was last modified: 06-18-2015 03:19 PM by Conrad.)
Post: #424
(06-07-2015 01:07 AM)Bean Bandit Wrote:  looking good, what does the weight pic include? I thought you'd be lighter than that despite the cage
Weight pic is the car with standard doors, standard door cards, FRP tailgate, carbon bonnet, all fluids plus a small amount of fuel in the tank. Front and rear bumpers plus side skirts to fit. Cool
06-18-2015, 03:49 PM
Post: #425
lexan windows rear and quarters?
Sent from my SM-T800 using Tapatalk
06-19-2015, 11:23 AM
Post: #426
(06-18-2015 03:49 PM)Bean Bandit Wrote:  lexan windows rear and quarters?
Lexan side windows, front and rear, lexan rear screen.
09-04-2015, 10:17 PM (This post was last modified: 09-05-2015 11:38 PM by Conrad.)
Post: #427
A few little bits done today, mainly just cleaning up and refurbing stuff but it needs doing none the less.
Last time home I noticed a fixing on the grille was broken so the grille was removed, repaired, cleaned up and refitted.
Only a minor job but needed doing, grille badge
The big hole where the strut brace used to be needs a plate welding in with an inspection cover so I can get to the wiper arm and linkage.
The hole..
The template... This will be welded soon when I have the inspection cover.
Next up the radiator brackets need some paint, I rubbed them down and masked them up ready to paint.
And painted.
And back on the car. Smile
Next up the airbox needed some attention, its difficult to see but it had blemishes and scratches everywhere. A quick rub down and its ready for paint.
And painted
Now its the wiper motors turn, no before picture on this one but here it is after the black paint is complete, I will refresh the silver part tomorrow.
Next up, I had some window trim missing on each door around the door mirrors, fortunately I managed to track some second hand pieces down, they just needed fettling.
Unfortunately the paint got damaged on this side but I will deal with this later.
The trim pieces..
I'll paint the trim pieces tomorrow.
09-06-2015, 10:08 PM
Post: #428
So continuing the theme the wiper motor got the silver parts rubbed down and painted today, it came out pretty good to be fair.
And connected to the wiper linkage and mounted.
Now I just need to work out how the MoTeC PDM has been wired so I can connect it up?
Door trims cleaned up and painted
Drivers side fitted, I can't fit the passenger side yet, I need to attach a stud.
Finally fitted the gear shift knob Smile
My new wiper linkage inspection cover is finished, original on the right, my new one on the left. Hopefully this gets posted tomorrow and then I get the bulk head plate welded in. Big thanks to Dave at Dave Flew Automotive for making this part as I couldn't locate an original piece.
Gave the throttle body trumpets a bit of a clean up Smile
A few photos to finish the day off, it's coming along albeit slowly.
Next up, fit the front and rear bumpers, side skirts and wire up the wiper motor.
09-06-2015, 11:09 PM
Post: #429
Love the detail... car is a work of art! Can't wait to see it completely finished!
09-12-2015, 09:47 PM (This post was last modified: 09-12-2015 09:51 PM by Conrad.)
Post: #430
It's been a few busy days, some progress and some negatives but onwards and upwards.
First up, trial fitment of the rear Run Free bumper
Fitment was ok across the back
But when the fabricators widened the arches they aledgedley had a fibre glass guy in to modify the bumpers to suit the new arches. As can be seen here, that never happened!!!
I need to find a Fibreglass specialist who can modify this bumper to suit.
With my latest discovery I thought I would try the front Run Free bumper to see if that had been modified, we are in luck, they did the front bumper, just not the rear bumper Sad
Next up, the inside of the car was bugging me, it was absolutely filthy, 3.5 years at the fabricators, 3 years at Zen so it was out with the seats and cleaning products to see what could be done. The 3 year old masking tape was a PITA to get off!
Clean up under way, tape off the door bars Smile
Arty shot.. Lol
Looking much better now
Eye bolts for the harnesses
Time to clean up my Bride seats, remove all the masking tape.
New bolts for the seats, much better than the mix and match set that were in there previously
One eyebolt on the drivers side is ok but the one on the tunnel may be an issue on my seat position, may need to move this later.
Seat back in its new clean environment with its new bolts
I couldn't resist trying the Takata harness, I need to get some buckles to wrap the rears around the roll bar once installed.
  ae86 racecar with beams engine bakonick 148 163,790 04-23-2024 10:06 PM
Last Post: bakonick
  Krullibulls Ae86 BEAMS is the only way krullibull 86 88,705 05-07-2019 09:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 735,832 09-03-2017 09:24 PM
  Beams Levin build mannix20vt 5 9,269 01-27-2016 12:39 AM
Last Post: mannix20vt
  Another AE86, Duracell. Now with VEMS, and cage... Uzelac 62 88,463 06-22-2015 02:56 PM
Last Post: Uzelac
User(s) browsing this thread: 18 Guest(s)
