AE86 front COILOVERS size
04-12-2011, 08:49 PM
Hi, everybody.
I'm Mitya from Ukraine. And I'm building 'track day' AE70 Corolla. Here... http://ae70.blogspot.com/ Recently I bought a pair of KeiOffice shock absorbers from some Dutsan. I bought them that would be adapted for my Corolla. But here is a question: how long should be good coilovers? What should be "A" that I could drop my bucket as possible down to the pavement? I will take into account any advice. Thanks in advance! http://ae70.blogspot.com/ & http://drft.io.ua/ |
04-13-2011, 09:59 PM
Nobody knows!?
04-13-2011, 11:12 PM
Just what I remember from my recent suspension upgrade:
extended shock 477mm +16mm spacer +~40mm rest of body A=~550mm thats how it looks with 8kg springs 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
04-14-2011, 10:37 AM
Thank you.
Just like I want to use... 8kg spring. How long is your front springs? http://ae70.blogspot.com/ & http://drft.io.ua/ |
04-14-2011, 01:46 PM
I forgot to mention, that I shortened the stock strut housings 20mm.
My springs came with former suspension setup, but with my changes the lenght of the spring is not ideal (200mm). If I had to choose I´d go for 250mm or even 300mm. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
04-14-2011, 03:08 PM
Thank God I'm guessed with a length of springs))) 10" (250mm)
Your sizes look like this? Do I understand correctly? http://ae70.blogspot.com/ & http://drft.io.ua/ |
04-14-2011, 07:45 PM
Yeap, that´s it!
Shim size for AM cams | kazi | 4 | 5,205 |
Hub size | kazi | 5 | 9,683 |
06-09-2017 10:06 PM Last Post: kazi |
Carina drivers! - Coilovers for a TA60/62 | nyberrg | 2 | 6,308 |
06-05-2017 10:03 AM Last Post: nyberrg |
Fitting driftworks CS2 coilovers | bozu | 2 | 4,688 |
05-30-2017 10:50 AM Last Post: bozu |
D2 Coilovers any good? | heshan | 18 | 26,222 |
04-04-2017 02:40 AM Last Post: hachirokkos |
