AE86 front COILOVERS size
04-12-2011, 08:49 PM
Hi, everybody.
I'm Mitya from Ukraine.
And I'm building 'track day' AE70 Corolla.
Here... http://ae70.blogspot.com/
Recently I bought a pair of KeiOffice shock absorbers from some Dutsan.
[Image: AEU86 AE86 - AE86 front COILOVERS size]
I bought them that would be adapted for my Corolla.
But here is a question: how long should be good coilovers?
What should be "A" that I could drop my bucket as possible down to the pavement?
I will take into account any advice.
Thanks in advance!
http://ae70.blogspot.com/ & http://drft.io.ua/
04-13-2011, 09:59 PM
Nobody knows!?
Huh
04-13-2011, 11:12 PM
Just what I remember from my recent suspension upgrade:
extended shock 477mm
+16mm spacer
+~40mm rest of body
A=~550mm
thats how it looks with 8kg springs
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
04-14-2011, 10:37 AM
Thank you.
Just like I want to use... 8kg spring.
How long is your front springs?
04-14-2011, 01:46 PM
I forgot to mention, that I shortened the stock strut housings 20mm.
My springs came with former suspension setup, but with my changes the lenght of the spring is not ideal (200mm). If I had to choose I´d go for 250mm or even 300mm.
04-14-2011, 03:08 PM
Thank God I'm guessed with a length of springs))) 10" (250mm)
Your sizes look like this?
Do I understand correctly?
04-14-2011, 07:45 PM
Yeap, that´s it!
  Shim size for AM cams kazi 4 5,413 12-18-2017 05:34 PM
Wink Hub size kazi 5 9,994 06-09-2017 10:06 PM
Last Post: kazi
  Carina drivers! - Coilovers for a TA60/62 nyberrg 2 6,565 06-05-2017 10:03 AM
Last Post: nyberrg
  Fitting driftworks CS2 coilovers bozu 2 4,927 05-30-2017 10:50 AM
Last Post: bozu
  D2 Coilovers any good? heshan 18 27,242 04-04-2017 02:40 AM
Last Post: hachirokkos
