AE86 front and rear brake upgrades
04-07-2010, 01:06 AM
hi guys,
im in the middle of rebuilding my f20c engined AE86
im looking to do a upgrade on the front and rear brake setup
ill be running 15inch wheels so will have to fit under them
can anyone give me any advice on wat can be got and any links to any sites that sell kits for front and rear.
thank you please Thumbs up!
04-07-2010, 10:35 AM
bump any help
04-07-2010, 10:55 AM
There is some info to be found on the forums I think..some threads specifically about the rear brakes. Did you read those? Worth doing a search on.
04-07-2010, 12:03 PM
For the front you can do the S13 suspension conversion with arms, hubs, sturts/coilovers, brakes. Use the facelift S13 brakes, discs are bigger.
For the rear I think you will need to upgrade the stock AE86 axle if you are running the F20C gear, so consider that.
04-07-2010, 01:15 PM
id like to keep my ae86 front end setup,hubs,suspension etc so would rather a direct bolt on upgrade for ae86,the rear im using a lite-ace rear axle with ae86 disc conversion but looking for maybe a 2pot rear brake setup.
any help or links to anyone on here that sells kits?
thanks you
04-07-2010, 01:19 PM
What type of use? Fast road, racing, drift?
04-07-2010, 01:31 PM
Front: Mazda RX7 FC turbo brake calipers, with redrilled Mini Cooper S discs and some adapter plates to mount them
Rear: There are some VW/Audi Caliper with Primera discs that will fit without to much work
And upgrade your master cylinder. There's one 1" from a Toyota Landcruiser that will fit almost plug and play
http://monkeymagic86.wordpress.com
  PWR light issue and no brake fluid after winter storage magpie 10 2,872 05-25-2023 08:09 AM
  Clutch and brake cylinders MIGGZFSU 4 5,496 10-14-2017 07:52 PM
Last Post: MIGGZFSU
  Front big brake kit DidiDex 14 18,981 10-24-2016 09:29 AM
Last Post: FanIsHere
  AE86 Rear Brake options. hachirokuGTV 66 125,088 08-27-2016 11:01 PM
Last Post: izanagi
  S13 Front brakes in AE86 rear heshan 25 29,067 02-01-2014 12:37 PM
Last Post: heshan
