AE86 notice (before going wild with mods)
09-11-2004, 11:49 PM
The AE86 is old and there isn't one that isn't a little bit rusty (only when just rebuild)
So before making mods be sure that everything that goes with that mod is in good condition meaning. When going to a difrent suspension setup be sure to check. - bushings - all state of the car (it will get more force because of stiffing the sus) - the top mounts If you do a engine tuneup check your. - pistons - crankshaft etcetcetc Best engine tuneup is to do a rebuild engine ![]() No reading this very annoying stuff you'll notice that getting an AE86 is hard but getting it into the state of desire is far and far much harder than you thought it would be Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
09-12-2004, 12:51 AM
robokill Wrote:but getting it into the state of desire is far and far much harder than you thought it would be That goes for every car in existance ![]() The trick is to take it one step at a time. Every moment you improve one part of your car, every year your car gets older another thing brakes down. The art is to improve more things each year then the number of things that brake down, only then you are heading to owning one sweet ride someday ![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
Going 20V BT! | pack | 27 | 25,779 |
06-04-2014 09:27 AM Last Post: D.O |
Effects of valve lift - worth it going higher? | harkes | 18 | 17,612 |
03-17-2014 09:21 PM Last Post: oldeskewltoy |
All I should know about suspension before any modification | damusto | 20 | 22,445 |
T50 weird gear set What´s going on? | fax0815 | 13 | 45,836 |
08-13-2012 04:50 PM Last Post: Project D |
Revs going up and down... | Okami | 8 | 9,479 |
06-28-2012 07:25 PM Last Post: Okami |
