Thread Closed
AE86 notice (before going wild with mods)
09-11-2004, 11:49 PM
The AE86 is old and there isn't one that isn't a little bit rusty (only when just rebuild)
So before making mods be sure that everything that goes with that mod is in good condition meaning.
When going to a difrent suspension setup be sure to check.
- bushings
- all state of the car (it will get more force because of stiffing the sus)
- the top mounts
If you do a engine tuneup check your.
- pistons
- crankshaft
etcetcetc
Best engine tuneup is to do a rebuild engine Smile
No reading this very annoying stuff you'll notice that getting an AE86 is hard
but getting it into the state of desire is far and far much harder than you thought it would be
09-12-2004, 12:51 AM
robokill Wrote:but getting it into the state of desire is far and far much harder than you thought it would be
That goes for every car in existanceSmile
The trick is to take it one step at a time. Every moment you improve one part of your car, every year your car gets older another thing brakes down. The art is to improve more things each year then the number of things that brake down, only then you are heading to owning one sweet ride somedaySmile
Thread Closed
  Going 20V BT! pack 27 25,787 06-04-2014 09:27 AM
Last Post: D.O
  Effects of valve lift - worth it going higher? harkes 18 17,621 03-17-2014 09:21 PM
  All I should know about suspension before any modification damusto 20 22,475 05-24-2013 09:28 PM
Last Post: damusto
  T50 weird gear set What´s going on? fax0815 13 45,845 08-13-2012 04:50 PM
Last Post: Project D
  Revs going up and down... Okami 8 9,488 06-28-2012 07:25 PM
Last Post: Okami
