AE86 rear axle weight
03-04-2013, 10:43 PM
No prob, actually, once you add wheels and tires, the rear axle sits right at 100kg unsprung weight. So it really just depends on what anyone is trying to lift.
03-29-2024, 11:18 AM
Reviving this thread as I'm about to install a Feroza rear axle on my 86.
Confirming that OEM late/kouki/thicker/25mm shafts/axles weight 11,3kg without bolts. Daihatsu Feroza/Rocky LSD rear axle detailed weighting 1. Each shaft/axle (converted PCD to 4x114,3): 7,20kg => 14,4kg for both 2. LSD differential, crown, pinion and pumpkin: 22,70kg 3. Axle/diff housing (no oil): 18,50kg So the Feroza/Rocky axle without brakes, panhard, swaybar etc weights 55,60kg in total vs the 86 axle which according to you weights 46kg. That's 10kg added weight. I will take the same measurements for the AE86 axle as soon as I remove and disassemble it. Follow: The story of my AE86 |
Axle width | totta Crolla | 1 | 1,058 |
light weight Flywheel | filh | 9 | 7,260 |
02-05-2018 05:20 PM Last Post: filh |
Rear axle options | Dino86 | 13 | 12,879 |
Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 3,784 |
wider rear axle,track width,suspension questions | ditn | 6 | 8,670 |
