AE86 rear axle weight
03-04-2013, 10:43 PM
No prob, actually, once you add wheels and tires, the rear axle sits right at 100kg unsprung weight. So it really just depends on what anyone is trying to lift.
03-29-2024, 11:18 AM
Reviving this thread as I'm about to install a Feroza rear axle on my 86.
Confirming that OEM late/kouki/thicker/25mm shafts/axles weight 11,3kg without bolts. Daihatsu Feroza/Rocky LSD rear axle detailed weighting 1. Each shaft/axle (converted PCD to 4x114,3): 7,20kg => 14,4kg for both 2. LSD differential, crown, pinion and pumpkin: 22,70kg 3. Axle/diff housing (no oil): 18,50kg So the Feroza/Rocky axle without brakes, panhard, swaybar etc weights 55,60kg in total vs the 86 axle which according to you weights 46kg. That's 10kg added weight. I will take the same measurements for the AE86 axle as soon as I remove and disassemble it. ![]() Follow: The story of my AE86 |
| Axle width | totta Crolla | 1 | 2,257 |
| light weight Flywheel | filh | 9 | 9,233 |
02-05-2018 05:20 PM Last Post: filh |
| Rear axle options | Dino86 | 13 | 17,035 |
| Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 4,621 |
| wider rear axle,track width,suspension questions | ditn | 6 | 11,352 |
![AEU86 AE86 - AE86 rear axle weight [Image: AEU86 AE86 - AE86 rear axle weight]](https://i.ibb.co/MhLrFLH/45782267-2164710247101236-2051748599338893312-n.jpg)
